What a effort - looks like a knight's armor!
996 Carrera 4 Cabrio, 2001, 300 hp, silver, black
911 SC, 1982, 210 hp, white, pascha
912, 1966, 90 hp, light ivory, black
Old 09-04-2018, 12:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
Flojo's Avatar
Great work!
Though I really do think it shealds the lines way too much from fresh air for cooling.
I do accept the argument of the G-cars having rocker panels, though theses do not sit that tight/close and the lines are free in the A-pillar area.
And as compared to tons of racecars having the lines non-shielded in racing, I see no need to do that at all.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-04-2018, 01:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
Indentations
Jon,
Did you use an air tool to planish the indents on the jig, or was it all manual? Curious what you anticipate the ratio of air inlets to exhaust to be...or another way of asking, will there be positive pressure in that shroud when complete?
Old 09-04-2018, 09:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
Jon Bingham
Send a message via Skype™ to TheMetalSurgeon
Speedo ,planning on 5 inlets to 1 exhaust.We will run the system on a current road going 912 with a Polo motor set up and record our findings.Depending on results we may run one size smaller crimped stainless mesh.
I hand/manually chased in the material to the 3 recesses in the jig.thanks
Old 09-04-2018, 05:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
Mmmm, purdy...
Kevin
Old 09-04-2018, 07:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
Jon Bingham
Mocking up a pattern for the air intake ,so we can make in one piece.
Old 09-05-2018, 06:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
Jon Bingham
Jig with added definition of lead
forming panel
Old 09-05-2018, 06:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
Jon Bingham
Chased in and metal finished
Old 09-06-2018, 08:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #168 (permalink)
Jon Bingham
Staggered in height for maximum efficiency , set of 4 air intake openings.
Old 09-07-2018, 08:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #169 (permalink)
Amazes me how you get the sheet metal to seemingly drape over the former like a cloth, or cheddar melting on an angus burger. John.
Old 09-08-2018, 10:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #170 (permalink)
Jon Bingham
Old 09-08-2018, 01:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #171 (permalink)
I am blown away by your craftsmanship, your work is art to say the least.
But i'm scratching my head;
What happens to all the door gaps when the car is on its own suspension at final weight?
I always thought the dimensions change under load.
Maybe that's just myth? But I seem to notice it when using a jack and opening closing doors.
Old 10-13-2018, 05:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #172 (permalink)
Jon Bingham
Thank you! nothing happens to the door gaps,i'd only be mildly concerned if it was a convertible and the longitudinals were shot and reconstructed with the aid of bracing.
Coupe ,with perfect inner and outer rockers 100% confidence.Yes its a myth,although id never heard of that before.
thanks again
Old 10-13-2018, 09:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #173 (permalink)
78-911SC's Avatar
Jon any plans for the bottom of the car. Stripping or repainting?
PJ
78 911sc Targa
70 911T
Old 10-14-2018, 06:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #174 (permalink)
Banned but not out, yet..
RSBob's Avatar
Masterful work with cool concepts too boot.
One question about cleaning out your new covers from dirt and grit. Do you intend to just flush it out with a hose? Looks like you have some good drain areas.
Old 10-14-2018, 06:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #175 (permalink)
Jon Bingham
adding and blending original spec undercoating .
Old 10-14-2018, 11:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #176 (permalink)
Jon Bingham
LH upper 40% air intake build
trimming around the headlight bucket
Old 10-19-2018, 01:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #177 (permalink)
Porsche Nut
merbesfield's Avatar
Originally Posted by TheMetalSurgeon View Post
Jon, beautiful work as always. Is there a way for all the little rocks and sand to escape out the bottom?
Old 10-19-2018, 01:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #178 (permalink)
Jon Bingham
thank you! yes im going to add them details ,just not decided on the form yet.thank you for following along
Old 10-20-2018, 09:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #179 (permalink)
Jon Bingham
LH radiator bracket modification
original RH bracket versus LH aftermarket
Modification begins
converting RH oil vent cover to a LH vent cover
mock up in car
Old 10-20-2018, 10:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #180 (permalink)
