tires/rims for 912
I'm looking to replace my stock rims/tires that are 195/15 195/165.
There are several used Porsche rims/tires on Market Place. What options do I have that will fit my 1968 912? Do I have to stick with 15" rims? width. |
You have a few options for your 68. For 15 inch rims you can use stock 5.5 width painted or chrome, 5.5 x14 Fuchs which were used on 912E and certain 911 cars with “comfort group” option as well as 911E. Then the price starts climbing with 7” wide 911R Fuchs, American RacingTorque Thrust 7”; one year only 1968 5.5 wide Fuchs; Mahle “gas burners.” For 16 inch diameter. I’ve seen SWB cars running 6 inch wide Fuchs (911SC fronts) all around. Keep in mind that when deviating from original size you might well run into rubbing issues with tires, offset, spacers, etc. As for tires, you’ll want to stay with something in the 25 inch diameter. range. I’m assuming you’re running 195/65r15.
Member cmpski has a SWB car that runs a Fuchs /tire combination that seems to be a solution that works and looks great. Last edited by WFBowen; 08-11-2025 at 08:56 AM.. |
Banned
If you’re replacing the stock rims and tires on your 1968 Porsche 912, it’s safest to stick with 15-inch wheels, ideally 5.5 or 6 inches wide. You can go a bit wider or even try 16-inch wheels, but you’ll need to make sure the bolt pattern (5x130) and offset fit correctly, so the tires don’t rub or mess with handling. Used Porsche wheels like Fuchs or Cookie Cutters can work well, just test fit before buying to be sure they’ll fit your car.
Keep in mind the look you want as well. I run 195x15" which does not have the stock/original look. I would buy 185 next time because the 195 in my opinion is just a little to large of a look
Tsunamiboy 1979 911 SC (3.2L) 1997 Boxster 986 |
You don’t have to stay with 15”, but larger diameters can look a little modern and reduce sidewall cushion and too wide of a rim over 6” usually means rolling fender lips or accepting occasional rub.
tires and rims
thank you all for your quick responses. The 195/65/15 I'm running is probably okay.
It appears that I best stick with 15" rims. The width max sees to be a 205/50/15. I will keep looking for used rims, Fuchs if possible. |
