chickybok's Avatar
Oil Pressure / Temp gauge into a 912
Hi Guys
Has anyone put a Oil Pressure / Temp gauge into a 912. I've picked up a 911s gauge (Pic attached).
Do I need new senders to make it work
(which ones and where can I get these from)
Also - If so... how do I attach them
I guess I can use the oil pressure switch for the yellow light!
Has anyone do this before????
Thanks again.... David
Old 01-29-2004, 08:51 AM
Look up Norv Parr at the Texas912.org , he just did this on his E...should be the same setup for the senders I would think.
Kevin,
1969 912
1992 Firebird
1985 Eldorado(SS roof)
1992 Ranger PU
1976 Cutlass(tha beast)
various others in the country for parts
Old 01-29-2004, 09:24 AM
chickybok's Avatar
Thanks - will do
Old 01-29-2004, 09:32 AM
912UK's Avatar
Dave how did you get on with it. As I have just got mine today and I am looking to do this soon.
Mark
Old 02-22-2004, 12:17 PM
Thumbs up
Dave,
I did that exact mod a year ago. It works great and looks cool.
First, I bought the gauge pictured in your post. Then, I removed both my oil temp sender and my oil pressure idiot light sender and sent them, along with the gauge, to Palo Alto Speedometer in CA. Palo Alto sourced two new senders and bench tested them for compatibility with the gauge. This testing is important since there are several different early 911S oil pressure/temp gauges (see Johnson's book) and since the 912 senders are different from the 911 senders.
The new senders from Palo Alto installed easily. The new oil temp sender looks identical to the original. However, the oil pressure sender is different in that it is from a 911 and it has two posts. As currently installed, I am only using one of the posts- the oil pressure level post. This is because I have not yet run the required second wire from gauge back to the engine. I am assuming that the second post is for an idiot light. If so, you could certainly use the parking-brake light as the idiot light.
That's how I did it. There may be other ways.
Cheers,
-E
Old 02-22-2004, 12:59 PM
oldbusboy's Avatar
I believe you need VDO 360 006 sender for oil pressure .. The temp gauge sender is VDO 323 055 .. at least for my gauge.
Trevor
Old 03-02-2019, 09:10 PM
