timing
Hi! i just finish to fix my new pertronic kit and i want to know the max advance i can put on .
thanks to taketime Mic |
28 at 2700
mic |
set it to a max advance of around 30 to 32 degrees, it should hit max around 3500 rpms, but don't worry about the RPMs, just the max advace. What disty are you running? Please do not say 009....
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe" Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S |
Yes Morrie,i have a 009. It's a problem???
thanks, Mic. |
abit off center
I dont think you can get max of 32 degrees out of a 009, if you do the advance at idle would be way too much? Try to find an 050 or 032 dizzy.
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thread Tools | |
Rate This Thread | |
