Question Mystery Screw Needs ID, Please
1966 Porsche 912 with 1968 engine. We have these ports coming off the inside-side of the manifolds. Each one has what seems to be hardened rubber tube (not sure if it was always hard or if it's just hardened with age) ending in a screw coming off of it. You can see pictures of it with and without. It's not actually part of the carb. I can't locate it in either of our manuals (912 Handbook and Clymer). Our best guess at this point is something to do with the primitive emissions system. Does anyone know? Click here for the first picture:Port with Tube & Screw Click here for the second picture:Naked Port
Old 09-01-2014, 06:44 PM
Hi Greg,
That's a vacuum port for the distributor. If your car doesn't have the original vacuum advance distributor (060 I believe), these need to be capped or you have a vacuum leak. Best would be to remove the carbs and replace that metal spacer with the bakalite one from a pre-'68 car. They are available on-line for several sources.
Another option is to run a piece of vacuum hose between the two ports.
Tony
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 09-01-2014, 10:12 PM
Tags
912 , solex
