jkeyzer's Avatar
fog light mounting?
Does anyone have pictures or a diagram of the stock 70-74 fog light mounting? I have the fog lights and the brackets on the lights but need to know what I am missing. How much adjustment is there in the stock setup?
Thanks!
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 04-10-2003, 12:43 AM
first pict shows threaded hole, the one in the partial circle. second will show f.l. w/ mounting bracket.
kevin
Old 04-10-2003, 05:59 AM
Puny Bird
Mark Henry's Avatar
Isn't that the horn mount hole?
The fog light mount hole is the one to the right and just below the hole your talking about, or am I wrong?
Old 04-10-2003, 07:57 AM
jkeyzer's Avatar
Is the foglight just bolted on or is there a cupped washer or other adjusting piece that goes on the bracket?
Jeff Keyzer
Old 04-10-2003, 10:11 AM
i was mistaken yest. mark is correct. the correct hole would be down and to the right in the pict. this photo shows the nut on the back side that sort of floats. it is held by a square "cup"welded on the back side of the front end.
kevin
Old 04-11-2003, 05:59 AM
Puny Bird
Mark Henry's Avatar
This is the set up that I just did, it works good:
http://members.rennlist.com/demick/lights.html
Thats how I knew you had the wrong hole. The only adjustment you have is bit of up/down, bit of side/side and tilt.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-11-2003, 06:42 AM
so my question is this. did the factory put the nut on all the cars as they came down the line?
kevin
here? not so much i think. high five!!!
Old 04-11-2003, 06:54 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Not on the 75-76 cars!
I did see it on the 70 which didn't have fogs.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 04-11-2003, 07:41 AM
