914 Drive train swap
When I was Younger I had a 73 914 Chalon Kit, Was think about doing another with a possible drive train swap? Options?
Boxter S trans and engine? Thoughts, anyone attempted or any other recommendations?
Old 09-19-2024, 09:16 PM
914 Geek
Boxster swap has been tried, but is not that easy. The engine is a little too wide to fit between the inner suspension mounting ears. This can be dealt with, but it's fiddly and challenging.
The V8 swaps have been common for decades. The small-block Chevy is a very popular swap.
Subaru swaps have become more popular in recent years. Mostly Imprezza WRX engines, but a few others as well.
Others have been done. Apparently a K20 Honda engine will fit. VW TDI four-cylinders for massive amounts of torque and great fuel economy. Nissan and Honda V6es. And so on.
Some of the above have also used Boxster transmissions. They're bigger and heavier than the 901 box, but can handle more torque. You may wind up losing at least some of the rear trunk space to use them. Subaru transmissions with the rear drive shaft output blocked off or locked out have also been used.
Lots of options. Some have been done more times and have "recipes" to follow; others require more engineering to be done. Places like Renegade Hybrids have a lot of knowledge of different swaps.
--DD
Old 09-20-2024, 11:00 AM
Thanks for info. I did run across the Renegade youtube channel, the 6.2 LS w boxter/trans would be wicked @ 455 HP. I currently have a 2015 Camaro 2SS with that motor? Couldn't imagine what that would be like in that light of a car? I have a 2008 Aston Martin V8V 4.3 380 HP but that's 3900lbs? I think If you're going to throw money at it it might as well go all i with 6.2 LS?
Old 09-22-2024, 02:47 AM
Non User
infraredcalvin's Avatar
If you’re gonna throw money at it, stick with a Porsche 6…
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 09-30-2024, 09:42 PM
Swap
Two points…..your car so your choice but Chalon seems to have lost its appeal……
Buy a correctly done swap…..you will likely save money ……but then again there is masochism��
TOT
Old 10-09-2024, 03:31 PM
I replaced my underperforming (on the track) 2.0 with a "built" 2.7 911 engine. I can tell you, the car is brutal on the street. To me, an LS conversion just means you're going to die faster. . . Old track joke. As previously said, a 911 engine transplant is what you need. They're easier, if that's a phrase that can be used here, as the car is designed to accept that transplant. The 901 doesn't need anything to beef it up for normal conditions and it just sounds amazing in third gear. My take. It is your car and you need to do what you think is best for you.
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 10-14-2024, 10:10 AM
