Arlen's Avatar
CV Joint Gaskets
Went to the local bug shop, they have most of the 914 parts I need. He says bug CV joints are a different size than 914, so the bug gasket for the CV joint won't fit. He no longer carries 914 CV joint Gaskets, and we both thought running without a gasket wouldn't be a big deal.
Is this a mistake?
Old 08-15-2003, 02:30 PM
roadtrp204's Avatar
Bugs have a lip on the flange that the cv mounts to that seems to seal the two pieces together well, I have never seen a bug cv leak grease between the cv and flange without a gasket. 914s on the other had have just a flat mating surface between the cv and the flange, without a gasket these seem to fling grease.
Chris
75 914 2.0L
Old 08-15-2003, 02:56 PM
Arlen's Avatar
Do you think running without gaskets on the cv's would be "ok"?
Old 08-15-2003, 03:49 PM
Banned
Alfred1's Avatar
Have you tried here at Pelican? If they don't have it, try your local Porsche dealer. My Porsche guy can get a lot of the parts I need.
Alfred
Old 08-15-2003, 03:53 PM
skline's Avatar
Pelican sells them for .95 cents each, I would consider it a very wise investment to buy about a half a dozen or so for future use. It will fling grease all over if you do not run them. Just my opinion.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 08-15-2003, 06:46 PM
M. Hendrix's Avatar
Plus there is a certain amount of grip that is allowed by the compression, it will come apart without gaskets, bet ya.. they like to come apart with them.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 08-15-2003, 07:16 PM
Zeke's Avatar
Use the gaskets and change the serated washers on the bolts each time you take them off. Actaully, you're not supposed to reuse the bolts, but I do if they are fresh. Pelican has all this in stock.
Old 08-15-2003, 08:39 PM
