Banned
Alfred1's Avatar
Is this a 1.8L motor?
I am considering buying this motor but the seller can't find the engine i.d. number.
Old 09-18-2003, 05:30 PM
Banned
Alfred1's Avatar
skline's Avatar
Look on the top of the motor back by where the transmission bolts go through it should be on the top of the block off to the right side. If it is a 1.8 it will be there. If it is not there, look between the oil filler and the fan shroud. Some of the 1.7 liter models had it there. Good luck.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 09-18-2003, 05:42 PM
hardflex's Avatar
looks like a djet 1.7 to me.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 09-18-2003, 05:45 PM
chrisreale's Avatar
1.7 is what I think
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 09-18-2003, 05:54 PM
It's got the 1.7 Aux Air valve and the bracket to hold the air cleaner. The tin is 1.7 or 1.8, so that rules out a 2.0 D-jet. You could also take a quick look at the distributor to see if it has a set of trigger points, which would be on a 1.7 but not a 1.8
2005 BMW 530i
2008 GMC Acadia
Old 09-18-2003, 07:19 PM
Banned
Alfred1's Avatar
Is this the throttle valve housing (circled in red)? If it is, then this should be a 1.8, no? The b/w pictures below are from the factory EFI manual and they illustrate the 1.8 AFC motor.
Old 09-18-2003, 07:36 PM
Banned
Alfred1's Avatar
Old 09-18-2003, 07:37 PM
Banned
Alfred1's Avatar
Old 09-18-2003, 07:38 PM
914 Geek
No, it's a 1.7 indeed. A 70-72 1.7, from the heater blower mounting. Also from the end of the motor mount bar that you can see. That's a tail-shift mount.
The 1.7 TB looks exactly like that; the 1.7 and 1.8 have the manifold and throttle body in the same location, pretty much.
--DD
Old 09-18-2003, 07:40 PM
Banned
Alfred1's Avatar
Ok, thanks all. I'm going to contact the seller and ask him to email me pics of his other (hopefully 1.8) motor.
Old 09-18-2003, 07:55 PM
skline's Avatar
Why? The 1.7 had more power than the 1.8. I would rather have the 1.7. Just my opinion. It you cant go 2.0 then the 1.7 is the way to go.
75 Slantnose V8
72 914 Parts car
Old 09-18-2003, 10:51 PM
Biggy72's Avatar
my 1.7 sure is strong. I don't know what a 2.0 would feel like but after tuning up mine tonight I'm pretty impressed..... maybe I'm just too used to a good ole 1600 dp...
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 09-18-2003, 11:51 PM
If you're going to do anything with it in the future the 1.8 has much better heads. As far as the stock hp, 80 (early 1.7) vs 73 (1973 Calif 1.7) vs 76 (1.8)... who cares? And, if you already have a 1.8 set up with L-Jet that you're replacing then it's likely better to match, and you'd get the right distributor, air valve, intake, etc., as spares.
2005 BMW 530i
2008 GMC Acadia
Old 09-19-2003, 04:23 AM
Banned
Alfred1's Avatar
Will98D is exactly right. I want to use a 1.8L motor as a base for building a 2258cc high-performance motor and since Jake Raby uses 1.8 or 2.0 heads in his 2270cc motors, I figured I'd do the same. I'll use the 1.8 heads as cores when I buy big-valve Type IV heads and I'll use the case for the rest of the big-four build up.
Old 09-19-2003, 12:39 PM
Banned
Alfred1's Avatar
You guys were right. The engine number is W 0062841 which, I think, makes it a 1.7L from a 1970.
Old 09-20-2003, 12:58 PM
914 Geek
Or 71, or possibly early 72.
--DD
Old 09-20-2003, 04:49 PM
