My 914 don't mind when I wake it up in the middle of the night and go cruising. It don't complain when I ride it hard and put away wet. It's easier on my credit card than the wife. It don't complain about being left alone for two weeks...... He!!, I'd marry it but for the fact I don't like oil stains on my sheets.... |
If only I had met her first
My 914, that is.
btw-do you percieve your car as male, female, neither, both (?), or what.... |
All my cars are female but with a nasty bite.....
***** stalls still damnit
m |
I was wondering about if my shift forks are bad will it show up in the performance of my fuel injectors and maybe if it does I should invest in some of those high performance fuel rails I keep seeing on ebay. And then I can do a rice style wheel upgrade to 5 lug shift knobs so that the exhast doesn't leak. That way when I'm racing at the AX and I step on the clutch the car will not go in reverse.
Shazam. |
I think your throttle bore is causing pistons, pushrods to the brake line, I mean lights.
Check the grounds at your interior, and lenses, look for wear around the door handles. The best exhaust for a 914 won't help. Porcshe tappets require yellow cup holders. M |
Paint it Yellow. It will work fine.
You've forgotten a few search terms.
steering rod rust weld paint cylinder bushing control tire brakes lines trunk storage top bracket seats carpet wheels shift swap ebay car sway body glass window trim wire wiring camshaft smilies 914 teener porsche part linkage repair fix ohio show auto-x 911 seal piston floor tar pad metal strut lug conversion six sixer shop garage jack interior dash switch bracket latch lock hood headlight relay harness console center gauge just a few...... Will this thread ever die? |
Not now! You said today's magic word!
M |
Hey, man, you started this beast; now you wish it to die? Good luck! It's taken on a life of its own. Who knows how long it'll take to die off? You've created too much fun, here. :D
Wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee........<p>s putter.......sputter...........Wheeeeeeeeeeeeeeeee eeeeeeeeeee.......<p>sputter....cough.........coug hhttp://www.pelicanparts.com/support/smileys/draai.gif http://www.pelicanparts.com/support/smileys/fart.gif http://www.pelicanparts.com/support/...s/pukeface.gif http://www.pelicanparts.com/support/...oilet_claw.gif SmileWavy<p><h3>IT'S ALIVE</h3>
who knew a BB could get cancer? Please, docter, before we suffer any longer...
Sometimes I search for used PORSCHE 911 parts, hoping to stumble across a PORSCHE 911 ENGINE.
Oh oh... |
he?
It is not worse than the Amazing Zanick and his BJ machine
oh this is good, bad fun ya...poof!
I don't wish for it to die---just surprised it's still growing.
When will Wayne or Dave step in? |
yea!
badbadbadbadbadbadbad dog
| All times are GMT -8. The time now is 02:54 AM. |
