Hi Guys,
I have fitted 3 sport comp Autometer guages in my centre console, that fortunately enough slip straight in to the existing holes. To match these, I am considering fitting a 5" tach in the place of the factory rev counter. Autometer do one in their sport comp range, and i have measured both. They seem to be the same size, but do you know if it will fit? Has anyone ever done it? The autometer tach comes with a casing, as it is designed to be dash mounted (freestanding), but hopefully, this cover can be taken off and the unit slipped in to the 914 instument pack. Please advise!!! Thank you, Luke. |
I have one in my 914 race car, fits a little snug but looks good. Check the race car article I have on the PP site here and I think there are a couple of pictures that show it.
fantastic!
thanks john. yours is a pro comp, and i want to fit a sport comp, but i presume they are the same size. could you just tell me how you fixed the shift light to the binnacle? thanks, I'm all excited now.
Just drilled a couple of small holes and used sheet metal screws.
Puny Bird
I have a monstrer tach in mine. Fits good, just used a bit of silly-cone and sat it in the hole.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
does it wobble around under vibration? |
No vibration, at least none I can detect. I did not tighten the screws as tight as I could so there is a little dampening from the material on the top of the dash. Good luck.
I use one, not the best pic but better than nothing.... Its got the small shift light on the tach. I don't even look at the tach anymore. When the light goes on, you see it in your peripheral vision.
that's a good picture, thanks. It shows what I need to see.
You just used straight forward screws too? I don't want to try it out and then realise I've made holes in my dash for a solution that doesn't work properly!!! thanks, Luke. |
I guess I used screws. It’s been so long I would have to look at the car tonight to verify. Please note the light on the dash is an OIL pressure warning light not a shift light. On the tach is a small shift light that works wonderfully.... So if your looking for just a shift light, buy the tach with the shift light mounted on the face of the tach and you will not have to put holes in your dash.
http://store.summitracing.com/default.asp?target=search.asp&type=bykeyword&searchtype=both&part=tach&x=12&y=9
ATM-233903 5 in. diameter, 10,000 rpm, shift lite, Auto gage, tachometer Today $95.95 look at the large pic to see the shift light |
Thanks again, MJ. I think I'll go for the external shift light, as it looks cooler and will suit the look of my car.
1975 Porsche 914 1997 BMW 323i Coupe |
