Angry 3 rear calipers later...
Just thought I'd share my latest triumphs -- and one small pain in the @ss problem:
1 relay that got rained on and shorted out [there may have also been battery acid issues, too -- long story] -- fixed.
1 brand-new-works-great clutch (thanks PP!) -- fixed.
1 brake master cylinder (again, thanks PP!) -- fixed.
Electrical short that took out the alternator -- and a lot of other wiring -- fixed.
Bled the brake system -- and found out that my year old right rear caliper does not adjust.
This is the third one. Of course, they were not PP calipers. [Hint: Two vowels, both the same....]
3 calipers and they were all defective. Okay, I know, I know. But can I just say that I bought these before I knew of PP??
But, at long last, the Orange Beast is back on the road. And running great!!!! Doesn't really stop too well though....
See you all on the road!
Old 02-24-2004, 05:21 PM
Just want to point out that either the inner or the outer (don't remember which) adjustment screw turns the opposite direction to adjust.
Old 02-24-2004, 06:04 PM
RETIRED
Joe Bob's Avatar
If you don't mind not having an emergency brake...front one fit on the rear and you can use BMWs on the front....70-72 can use the 320i calipers bolt on....73 and up will need a little maching.
You get a bigger and cheaper caliper made by the same comany (ATE) and you get rid of those POS rear ones....
2012 ML350 3.0 Turbo Diesel
Old 02-25-2004, 02:53 PM
hargray2's Avatar
stupid ques: If fronts fit on rear and BMW's fit front, why can't you put BMW's on the rear?
"Don't make me make you let me!"
www.914club.com
Old 02-29-2004, 12:26 AM
914 Geek
You can. But that will upset the braking balance of the car, most likely.
--DD
Old 02-29-2004, 08:26 AM
RETIRED
Joe Bob's Avatar
You can but you wil most likely need a adjustable proportioning valve and/or more agressive pads in the front.
Old 02-29-2004, 01:37 PM
