coil
I have a wire coming out of harness near 12 pin plug it is yellow,its not the one that belongs on plug that one is there,this one has bayonet connectorand is about 12 inches long.
Jack One of these days it WILL run.
Be more specific, I might be able to help you out. I am pretty good with the wiring diagrams. What side of the car?
Year, Engine? |
914 Geek
Is it a 1.8? If so, then chances are this is the "Ok, I'm cranking the starter now" wire that connects to the FI. It should plug into one of the pins of the four-pin connector at the left-rear corner of the relay board. Numer 2 (II), which is the right-rear pin according to my reading of the wiring diagrams.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
