914/VW Transporter FI
My 914/4 2L fuel injection unit has packed up, and I've located a VW transporter 2L fuel injection unit which I am told is equivalent. Is this correct, or are the temp/pressure sensors calibrated differently ??
The "GE" block 77-79 bus engine I had came with an L-jet type of FI. So there are basically NO interchangable parts. It is basically the same as the 914 1.8L L-Jet but as you said the calibration would be completely different.
It is possible that other year Transporters had D-Jet but I doubt it. Key indicators of a D-Jet is the brain is about 1.5 times the size, the distributor has a 3 pin plug on the side, and there is a manifold absolute pressure sensor vs. the air flow meter on a L-Jet. From my fumbling around with it the wiring harnesses don't look like they would even swap. Also I've heard the injectors are different resistences so swapping them is a bad idea too. |
JP is right about the fuel injection system. No transporters came with D-Jet injection. Early ones, in fact everything under 2.0 had carbs. Even the Vanagon used the L jet when it was introduced in 81. Don't waste your time with the L jet. Get your D jet fixed. I am sure you will be happier with it in the long run. Just my opinion.
914 Geek
How do you know your FI has "packed it up"? If you suspect it has, I suggest hunting through Kjell Nelin's D-jet Guide on the 914 Fan Page.
http://www.914fan.net It's in the "Tech Refs" section. It does have one typo, though. It says to check the MPS resistance between pins 8 and 10, and between 7 and 10. The second 10 should be a 15, so you are checking between pins 8 and 10, and between pins 7 and 15. --DD |
