Another first place
It`s been many years in the making(restoration). I`ve been taking it to the local car shows.(Just had to show it off) This was the third show I`ve entered and my 2nd First place!Now I`m looking for a place to autocross it a little. Not to many events around here.
72914S |
More details. Stock, Modified etc....
1973 914-6 3.2 Motronic |
I`ts a `72 not quite stock, has a `73 2.0 with aries flat top 96 mm pistons,HD valve springs,all internals balanced,mild cam,lightened flywheel,HD oil pump,crane ignition,msd 6a,all that with a side shift trans and stock F.I. with a little tweeking done(still working on that). Bilstein all around w/140 springs also both stock sway bars,195/60/15 tires on Fuchs.Four coats of single stage ppg`77 guards red.Interior is stock with a console from a `73 w/clock,oil pressure,and volt guage.Dash has the combo fuel & temp guage. These mods where made because of what I have been reading here and That OTHER place where I`m known as "72914S" I been driving it for almost two years now.I GUESS i`ll never be done with it. Specially if you all keep coming up with more improvements THAT I WANT TO TRY. HA HA HA
72914S |
