need help with project (interior)
Im just getting around to starting my restoration, the car has been in the drive way for the past 2 years... i took the cover off and inspected everything.. couple of rust bubbles on the paint.. but that was happening 2 years back so nothing new rust places are still the same... well the help i need is that the vinyl on the inside seats backpar innerdoors... has spots of mold how do i get rid of the mold the interior is new.... was new what can i clean and kill the mold with..
its not leather so vinyl might me easier to clean thanks for the help
Blue 73' 914 1.7 |
the mold and mildew wasnt there a year ago.. it seems to wipe off with my hand... what should i clean it with to kill the bacteria.
dishwashing solution? water with a little bleach?
Blue 73' 914 1.7 |
30 views? no one knows how to remove mold off of vinyl?
Blue 73' 914 1.7 |
A *mild* solution of bleach in water is good on mold. Obviously, don't get it on the carpet.
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
Control Group
You are getting moisture in there or it would not be doing that, want to check that out, also look at floor near back pad for rust.
There are a lot of commercial fungicide's out there. I don't know if it would damage the vinyl though. If you use bleach on it, you will want to clean it off well and put some Lexol or other vinyl conditioner on it so it does not get too dry
She was the kindest person I ever met |
