FEnder beading
Looks like Pelican no longer carries the front fender/cowl fender beads. Anyone have an alternate source?
Jeff Donnelly ---------------------- 92 325i 71 914 w/2.0 and webers (needs paint) 74 914 potential driver, or maybe parts car. |
Black RTV
72914S |
try a product call duramix. its a two part urathane and the nomber 4126 i believe its called controlled flow or self leveling seam seal, check out the local paint shops or body shops, i used this on a restoration car and the good news is that it will flow into the gap and eliminate rust from formingm just mask off a 1/4 wide area on cowl and fender , put tape on inside of door and trough area of fender to dam up material so it wont run down jamb or into fender area, apply into seam to achieve the height you want not to much and watch it flow, once set up aprox 10 mins, temp has sometthing to say about set up times, then pull tape off and your done, can be panted or left black, if you want to leave it black paint car then apply, hope this helps steve
Try GPR. That is where I got mine.
1-800-321-5432. Dave it the man. Rob |
Hell Belcho
I believe you can use the 911 fender beading. you just trim it to fit Pelican carries it
Saved by the buoyancy of citrus. |
Thanks!
RTV??????NEVER
Please, look at pelican list for body seals again,,there are there as of last night,,,both early and late style dont use RTV YOU WILL BE SORRY APSAL |
