Brother's Avatar
Starting at the front trunk
Here's what I'm starting with.
Not too bad. The car had aftermarket air conditioning, so the hole in the floor needs to be patched and welded shut. There really isn't a rust problem in the trunk, but I am thinking of POR-15ing the entire inside.
Here are a few more shots.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 01-21-2007, 06:36 PM
Brother's Avatar
Here is my first question. The smaller hose that is coming out of the charcoal canister is only about 8 inches long and goes nowhere. Where should it go? It seems like it might go to the small hose that is coming out of the gas filler neck. It doesn't seem to go anywhere either.
Paul
1972 914 - Sold
Old 01-21-2007, 06:40 PM
Banned but not out, yet..
RSBob's Avatar
It should go to a vapor expansion tank which sits on top of the fuel tank - which yours is missing.
Old 01-21-2007, 07:17 PM
Brother's Avatar
Which one?
Paul
1972 914 - Sold
Old 01-21-2007, 07:27 PM
914 Geek
Which what? There is an "expansion tank" that should be on top of the fuel tank, wrapped partway around the filler neck. The cannister should have the small hose connected to the expansion tank.
--DD
Old 01-21-2007, 08:26 PM
Brother's Avatar
Which hose?
There are two hoses I was asking about. They are both the same size. One is coming out of the filler neck. I gather it is supposed to be attached to an expansion tank. Anyone have a picture of that?
The other hose is coming out of the canister on the right side of the fuel tank. I still don't know where that is supposed to go?
Is any of this stuff useful? Necessary?
Paul
1972 914 - Sold
Old 01-22-2007, 05:21 PM
914 Geek
I believe both small hoses go to the expansion tank.
Here's a picture that I found on evil-bay:
You'll have to use your imagination, but this thing wraps partway around the fuel filler neck and lays on top of the tank.
Its function is to provide an isolated air space so the tank can "breathe" as things expand and contract. It also provides the air that goes into the tank as the gas comes out. The expansion tank is what is vented to the charcoal cannister, which absorbs the fuel vapors so you get less evaporative emissions and less fuel smell.
Useful? Yup! Necessary for the car to run? Nope. (I believe it may be a legal requirement to keep the system intact, though.)
--DD
Old 01-22-2007, 07:49 PM
Originally posted by Brother
Which hose?
I just went out and shot these pics for you:
Hose #1
And hose #2
As far as usefulness, its there for a reason, which you may not care much about. If you can make it correct, I am sure the environment would love you for it.
Old 01-22-2007, 07:59 PM
Brother's Avatar
Okay, thanks. That makes sense. I was wondering about an unused bracket that was between the window washer bottle and the fuel filler neck. I'll look for a used one.
Paul
1972 914 - Sold
Old 01-23-2007, 03:56 AM
GreenWater's Avatar
Hey, I think I have a vapor expansion tank if you need one. I am not using it and will give it to you, just pay for shipping. I will have to look for it Friday if you want it, but I am almost positive I still have it.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 01-24-2007, 11:10 PM
Brother's Avatar
Greenwater,
Thanks. PM sent.
Paul
1972 914 - Sold
Old 01-25-2007, 05:34 PM
Brother's Avatar
Sheetmetal ordered today. 20 Ga Cold rolled steel for the hole. I'll start the grinding this weekend.
Paul
1972 914 - Sold
Old 01-25-2007, 05:35 PM
degreeoff1's Avatar
Why not just buy a 911 six and use that hole for a front mounted oil cooler??
Think it'd be easier....(just kidding) I know I am converting one now...HELL of a lot of work..:-)
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 01-26-2007, 07:02 AM
Brother's Avatar
Show me a picture of an oil cooler setup. If it is like a 911's, that might be doable now even though I don't need the cooler now. I will later.
I'm planning on installing a 916 front bumper in the near future.
Paul
1972 914 - Sold
Old 02-04-2007, 03:35 PM
GreenWater's Avatar
Brother,
I have a 916 front bumper as well. It is really heavy though.
84 944
Old 02-04-2007, 04:10 PM
914 Geek
Armando Serrano has tons of pics of the factory 914-6 GT cars. Their oil cooler setups were pretty effective. You can see the ducting for one about halfway down the following page:
http://www.pbase.com/9146gt/factory_9146gt_race_cars_roy_walzer
Click on the thumbnail for a larger version.
--DD
Old 02-04-2007, 04:28 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Just buy the front trunk floor out of a scraped 914 as it fairly easy to install and weld the floor in. I've done it.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 02-05-2007, 10:06 AM
Brother's Avatar
I cleaned the rust off and sprayed some primer around.
The POR-15 kit was ordered a few days ago.
The expansion tank arrived yesterday. Thanks so much.
The sheet metal should be here next week. The welder supply place messed up the order.
Paul
1972 914 - Sold
Old 02-07-2007, 06:03 PM
Brother's Avatar
Por-15 trunk restoration kit arrived as well as the 4'x10' sheet of metal. I'm ready to start cutting and welding.
Paul
1972 914 - Sold
Old 02-19-2007, 05:08 PM
Brother's Avatar
A little update.
I cut all the crappy metal out of the floor of the trunk. I still have some left to remove before I weld in the new metal I got.
I also removed the old bumper in preparation for installing the 916 front bumper I got from Greenwater.
Paul
1972 914 - Sold
Old 04-01-2007, 08:33 PM
