elwood-914's Avatar
Headlight Relay
I installed a new headlight relay in my 73'. Now I don't have high beams, I pull back on the turn signal arm and nothing, no clicking. I do recall somewhere that you had to install a jumper, I did a search at another site to no avail. Anyone have this problem?
Thanks.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 02-18-2008, 06:19 PM
Out of curiousity, what happens if you reinstall the old relay? Mike
Old 02-18-2008, 09:19 PM
elwood-914's Avatar
I'd have to find it again. The reason I replaced it was, I had low beams but when I went to the high beams, once in awhile the would drop to low and jump back to high. Then other times it would just stay on high just fine.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 02-19-2008, 05:37 AM
Control Group
Tobra's Avatar
sounds like the wrong relay or a defective one. The relay from a '69-'70 VW(pretty much any of them) is the same and less than $10. I did not need any jumpers when I replaced mine, just plugged it into the fuse block
Old 02-19-2008, 07:14 AM
elwood-914's Avatar
Thanks! I'll give it a shot.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 02-19-2008, 05:55 PM
porsche914gt's Avatar
You have to add a jumper wire to connect pin 30 to the red with a white tracer that is connected to pin 56. The red with a white tracer feeds power to the light circuit. and the relay toggles that connection between the yellow wire on pin 56a, and the white wire on pin F. Pin S connects to a yellow with a red tracer wire, and that is connected to the turn signal switch. When it grounds pin S, the relay is momentarily energized, toggling the state of the contacts to change the beam.
Put a jumper from pin 30 to pin 56. Pin 56 can be identified by the red with a white tracer wire.
Old 02-19-2008, 06:52 PM
elwood-914's Avatar
That's the info I was looking for.....
Thank you very much!!
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 02-22-2008, 07:12 PM
The Kelzer's Avatar
Perfect timing on this thread! Ok, the jumper helped...but now it's a 50/50 chance that the headlights are going to come off of whatever setting they were on when I pull back on the turnsignal lever. The relay clicks but the switch to high from low or visa versa isn't happening 100% of the time.
HELP! I've actually been chasing this one for over 5 years!
Mahalo,
Kelly
Old 03-04-2008, 01:18 AM
The Kelzer's Avatar
Anyone??
Bueller, Bueller, Bueller....
TK
Shouldn't we be out enjoying our Porsche's right now instead of sitting in front of a computer??
Old 03-06-2008, 10:07 AM
The Kelzer's Avatar
Nevermind.... I got it. The little tab in the relay wasn't straight....so I straightened it. MUCH BETTER!
Laters,
TK
Old 03-06-2008, 10:58 PM
Control Group
Tobra's Avatar
et voila!
Better the $relay$ than the $$switch$$ anyway
Old 03-07-2008, 06:13 AM
