Va914's Avatar
Post Front trunk spring
Does anyone have instructions on how to install the front trunk springs?
I took one off, scared the living $h*t out of me so I left the other one on. There is alot of stored energy in them springs!!!!!!Now I ned to put the one I took off back on. Any ideas.
Old 10-27-2001, 03:17 PM
RETIRED
Joe Bob's Avatar
Post
Front trunk springs are pretty easy.....get a helper to hold the lid open or a SAFE way to prop it open. Get a "T" handle hook tool or use a doubled up coat hanger.
Put the hook around the end of the spring and while standing in font of the car pull towards you. Install one perch at a time, alternating sides....
Old 10-27-2001, 03:25 PM
ejm914's Avatar
Lightbulb
Get a brake spring tool from your local flaps, then notch and grind the end like this. One end goes around the bracket and the other grabs the spring.
Ed Morrow
Old 10-27-2001, 05:24 PM
Va914's Avatar
Red face
Thanks guys.
I figured better ask then maybe lose a finger or eye. That screwdriver wasn't working to well.
Old 10-27-2001, 05:53 PM
Smile
Yup, them things are stiff!!! used Ed's method few weeks back. Happy dance all around when the hood don't bonk me on the noggin no more.
pbanders's Avatar
Send a message via Yahoo to pbanders
Post
I've used the Zois method for years, works fine and only costs you a coat hanger. Use a scrap piece of old garden hose for a soft handle.
Another tip is to make sure the pivot bolt is properly adjusted. Mine was too loose, causing binding which kept the hood from opening all the way. It was like this for years, I thought I needed new springs, until I adjusted it.
Brad Anders
Old 10-27-2001, 08:50 PM
Thumbs up
I used a small crowbar. I just hooked the nail-puller end between the coils and gave a big tug. Worked like a champ.
===Bernie===
Old 10-27-2001, 09:05 PM
