Fi 2
Will a fuel injection system from a 73 1.7 914 work on a 72 1.7 914?
Old 04-21-2010, 04:38 AM
914 Geek
Yes. Very much yes if you get the whole thing; I'm not quite as sure if you start to mix and match pieces.
--DD
Old 04-21-2010, 07:54 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
IIRC, the brain is a bit different as it has a adjustment screw on the top on a '73. There really should be no problem doing this. If you can, use the air filter assembly from the '73, it's less messy.
Old 04-21-2010, 08:58 AM
