Guest
Posts: n/a
I am contemplating the MSD 6A for my 1976 914-4 2.0. I assume I will need the tach adapter as stated but I was thinking of replacing the points with mag pick up unit. There shouldn't be any problems with this should there? You just use the different wiring scheme right?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Installing the MSD Electronic Ignition System |
Author of "101 Projects"
It's pretty straightforward - you might not even need the tach adapter. I would try it without the adapter and see if it works. I do indeed recommend the Pertronix system - it works very well in these older cars.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I agree but, in warmer climates the pertronix dont hold up very well against the heat.
In the shop at Pelican
I drove a pertronix equipped 914 for years in the high desert of California and never had a problem.
It really is worth it to get rid of the points once and for all. Honestly, there isnt much point to running a MSD 6 or 6A on a stock 914. If you're running a high compression motor with Webers, then yes, it makes a difference. I'd reccomend the Pertronix on ANY points equipped distributor. |
I cannot personally condemn the pertronix, only that i had asked DR.914 about putting on on mine and was told they dont hold up to the heat. I will put one on mine and see how it does.
914 Geek
What they hate is being hooked up backwards. It's a very quick way to smoke them, hook the + wire to ground and the - wire to power.
They also don't like the key being left on for more than ~30 seconds without the engine running. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
canna change law physics
Jared,
I don't know if it was just a tired CD unit, but putting the MSD into my 914/6 really smoothed out the low idle. Robin, There is a tach specific output on the MSD. Run the tach wire there and you will not have a problem with the multiple sparks on the lower revs.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
[QUOTE=red-beard;5975004]Jared,
I don't know if it was just a tired CD unit, but putting the MSD into my 914/6 really smoothed out the low idle. [QUOTE] I should have specified 914-4's. The MSD itself is a CD unit, and a great replacement for the stock Bosch and Perma-Fail units on the 6 cylinder cars. |
Get the MSD Billit Electronic Dizzy to go with the MSD 6A and you will be pleased
Agreed with Carr914
Do the whole thing distributor and ignition box. Make sure you get the box with a rev limiter. |
[QUOTE=Jared at Pelican Parts;5975032][QUOTE=red-beard;5975004]Jared,
I don't know if it was just a tired CD unit, but putting the MSD into my 914/6 really smoothed out the low idle. Quote:
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 Last edited by red-beard; 04-21-2011 at 11:18 AM.. |
Max Sluiter
Original RS spec(8.5:1 compression) is 210 hp @ 6300rpm and 188 ft-pounds of torque @ 5500rpm measured at the flywheel, I thought.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I think the shop did a little machining and the CR was higher than 8.5:1
My intention with that engine was using the 2.2 liter P/Cs and the 2.7 crank and going high compression. When the P/Cs were found to be barely inside spec, EBS had a deal on the RS P/Cs. I have had the car for 2 years, so I can't go out and measure it for you...
