Robin1 (guest)
Guest
Posts: n/a
I am contemplating the MSD 6A for my 1976 914-4 2.0. I assume I will need the tach adapter as stated but I was thinking of replacing the points with mag pick up unit. There shouldn't be any problems with this should there? You just use the different wiring scheme right?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Installing the MSD Electronic Ignition System
Old 04-17-2011, 07:49 PM
Author of "101 Projects"
Wayne 962's Avatar
It's pretty straightforward - you might not even need the tach adapter. I would try it without the adapter and see if it works. I do indeed recommend the Pertronix system - it works very well in these older cars.
- Wayne
911t Fanatic's Avatar
I agree but, in warmer climates the pertronix dont hold up very well against the heat.
Old 04-19-2011, 08:53 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I drove a pertronix equipped 914 for years in the high desert of California and never had a problem.
It really is worth it to get rid of the points once and for all. Honestly, there isnt much point to running a MSD 6 or 6A on a stock 914. If you're running a high compression motor with Webers, then yes, it makes a difference.
I'd reccomend the Pertronix on ANY points equipped distributor.
Old 04-19-2011, 09:11 AM
I cannot personally condemn the pertronix, only that i had asked DR.914 about putting on on mine and was told they dont hold up to the heat. I will put one on mine and see how it does.
Old 04-19-2011, 01:48 PM
914 Geek
What they hate is being hooked up backwards. It's a very quick way to smoke them, hook the + wire to ground and the - wire to power.
They also don't like the key being left on for more than ~30 seconds without the engine running.
--DD
Old 04-19-2011, 03:56 PM
canna change law physics
red-beard's Avatar
Jared,
I don't know if it was just a tired CD unit, but putting the MSD into my 914/6 really smoothed out the low idle.
Robin,
There is a tach specific output on the MSD. Run the tach wire there and you will not have a problem with the multiple sparks on the lower revs.
James
Red-beard for President, 2020
Old 04-20-2011, 01:01 PM
[QUOTE=red-beard;5975004]Jared,
[QUOTE]
I should have specified 914-4's. The MSD itself is a CD unit, and a great replacement for the stock Bosch and Perma-Fail units on the 6 cylinder cars.
Old 04-20-2011, 01:14 PM
carr914's Avatar
Get the MSD Billit Electronic Dizzy to go with the MSD 6A and you will be pleased
Old 04-21-2011, 06:20 AM
Agreed with Carr914
Do the whole thing distributor and ignition box. Make sure you get the box with a rev limiter.
Old 04-21-2011, 07:13 AM
red-beard's Avatar
[QUOTE=Jared at Pelican Parts;5975032][QUOTE=red-beard;5975004]Jared,
I also ended up replacing the Mirebelli distributor with a Bosch "S" unit. It made sense anyway, since I had "S" cams installed in the engine, along with an RS spec P/C set, along with completely rebuilding the case (Case savers, piston squirters, etc) and porting the heads. And in the end, I replaced the carbs with Zenith's that were setup for the car. Wow, what a difference all of that made! An RS spec 2.7 is supposed to be 240 hp. I don't know if it was there, never dyno'd. But it was definitelty at least 200+ from the accellerometer dyno I tried.
James
Old 04-21-2011, 08:59 AM
Max Sluiter
Flieger's Avatar
Original RS spec(8.5:1 compression) is 210 hp @ 6300rpm and 188 ft-pounds of torque @ 5500rpm measured at the flywheel, I thought.
Old 04-21-2011, 09:58 AM
red-beard's Avatar
I think the shop did a little machining and the CR was higher than 8.5:1
My intention with that engine was using the 2.2 liter P/Cs and the 2.7 crank and going high compression. When the P/Cs were found to be barely inside spec, EBS had a deal on the RS P/Cs. I have had the car for 2 years, so I can't go out and measure it for you...
James
Old 04-21-2011, 11:24 AM
