DDS DDS is offline
Gradual fuel pressure decrease.... Why?
Hi all,
After 5 years parked and an engine transplant, the car starts and runs great, 3psi on the regulator to start, after about 5-10 minutes (or less) running fuel pressure gradually drops (over several minutes) to nearly zero.
Running 44 idfs. Fuel system comprises tank>filter>pump>regulator/gauge>carbs.
I replaced the filter and the pump and there was no change.
Are symptoms consistent with a bad regulator? Could storage have gummed it up or caused it to malfunciton?
Thanks, Dave
-- Dave
'73 914, 2056 GT/SC done!
'69 Lotus Europa S2 - under resto.
pics at
http://www.syer.net
Old 04-09-2012, 07:43 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
after 5 years parked, I'd be tearing the carbs apart and soaking them in solvent.
But yeah, sounds like you have a bad regulator. What kind is it?
Old 04-09-2012, 07:52 AM
DDS DDS is offline
Thanks Jared - engine is a brand new FAT build, new 44 IDFs. I can't recall the make of the regulator. I may crack it wide open and flush it, maybe it is partially blocked?
Do regulators simply restrict/constrict the fuel flow?
THanks.
-- Dave
pics at
http://www.syer.net
Old 04-09-2012, 07:58 AM
You need to figure out what regulator you have. Get a picture.
Yes, a regulator works off the idea of constriction, think thumb on the end of a garden hose.
We arent talking a lot of pressure here with carbs... 5psi at the most.
What fuel pump are you running and WHERE is it located?
Old 04-09-2012, 08:04 AM
What kind of gauge are you using as well? Is it calibrated?
Old 04-09-2012, 08:09 AM
DDS DDS is offline
Holley fuel pressure regulator Summit fuel pressure gauge - at-speed photos
Holley regulator and gauge, not calibrated, basically identical to the setup pictured. Both sat while car was stored.
Have run two different pumps to cross check. First a US made pump, looks like a small bosch, worked fine with prev. engine, sat while car was stored, I susepct it was still OK. Second just installed, a brand new carter. I suspect I wasted some cash on this.
Pump and filter are installed in front trunk, beside spare, big (new) fuel filter first, then pump. Regulator is in engine bay, below battery tray.
Dat's it.....
-- Dave
pics at
http://www.syer.net
Old 04-09-2012, 08:16 AM
John Rogers's Avatar
Since this is a double post, see my answer in the other one.
Old 04-09-2012, 08:20 AM
DDS DDS is offline
Based on your thumb on hose description, I bet there is something blocking the regulator once the fuel starts to flow.... I had suspected this and blew out the the line backwards, but may not have cleared whatever is blocking. Thoughts?
-- Dave
pics at
http://www.syer.net
Old 04-09-2012, 08:21 AM
If there's no blockage, John's probably right.
Old 04-09-2012, 08:31 AM
DDS DDS is offline
Just disconnected the carbs, backed off the regulator, ran the fuel pump, dumping the gas into a glass jar. Some bits of black rubber like stuff in the first half gallon, clean after that. reconnected, went to adjust the regulator and it would not reduce the fuel pressure which sat 9psi. I see that regulator has a rebeuld kit which includes a rubber diaphragm..... hmmmm
-- Dave
pics at
http://www.syer.net
Old 04-09-2012, 09:30 AM
That is the same regulator I used on the race car and I had to rebuild it every 3 years or so. The guys that ran "street" gas had to rebuild it every 18 months or so as the chemicals in the gas will eat the neopreme right up. Worse if the car does nor run often enough to fully flush out the fuel system. I used to use Marvel Mystery Oil in the gas, even race 100 octane as it was not as good in 2010 as it was in 2000. You can always open it up to see what the internals look like?
You did not mention the tin or seals and if the regulator is under the battery tray then that area can get really hot.
Old 04-09-2012, 12:00 PM
DDS DDS is offline
Tin is fresh and intact and seals are in place. One hole on drivers' side where ductwork went, will seal that, 914/6 oil tank holes, will leave those.
The problem occurs even though the engine and bay do not get exceptionally hot (yet). The weather here is cool. I have not put the cooling system to much of a test yet, but all is in good order, including the thermostat bellows which works as it should.
This is adding up fast, thanks. I will be picking up a rebuild kit tomorrow, and will install a clear fuel filter in the engine bay, as much to monitor the condition of the regulator as anything else.
Thanks for the guidance.
Are you aware of a more long-lived regulator?
-- Dave
pics at
http://www.syer.net
Old 04-09-2012, 12:37 PM
Are there insulators between the carbs and the manifolds?
Old 04-09-2012, 01:46 PM
DDS DDS is offline
Thick gaskets anyway - 1/8" or so. Does that count? Tall manifolds too.
-- Dave
pics at
http://www.syer.net
Old 04-09-2012, 02:48 PM
No, see my post in the other one you made.
Old 04-09-2012, 07:45 PM
DDS DDS is offline
OK, thanks guys. I will deal with the supply issues first and test. I'm certain that the problem described occurs with cool carbs and engine bay. Once that's fixed we'll see what happens when things heat up a bit more.
Thanks very much for the guidance.
Dave
-- Dave
pics at
http://www.syer.net
Old 04-10-2012, 02:57 AM
DDS DDS is offline
Update:
Upon disassembly, regulator does not APPEAR to have a problem, however it is possible that there may still be some crud in the lines below.
Am contemplating options, there are some things I should change about this setup while I'm at it. Like the need for a fuel pump that requires a regualtor at all, or installing anything that may require maintenance below the battery tray or having multiple inaccessible hose clamps buried inaccessibly under the car, or.....
-- Dave
pics at
http://www.syer.net
Old 04-14-2012, 04:39 AM
I suggest you look for Bob Tomlinson's Original Weber Tech Manual or Pelican Parts.com - Haynes Carburetor Manual this right here.
You need to do a bit of reading before going any further. Thick gaskets are not the same as carb insulators. I suggest you read up on the basics, then come up with an idea for a fuel system based off of that.
FAT Performance should have also given you an idea of how to set up the carbs for this engine.
Old 04-16-2012, 07:12 AM
I've been thinking about this problem some more.. What kind of cam and headwork does your engine have?
44's may be too much for your engine.
Old 04-17-2012, 07:44 AM
DDS DDS is offline
Engine is a turnkey FAT motor, dyno tuned and run in with 44IDFs in place at their facility. Idles beautifully, runs great, very strong, until fuel pressure drops. Heads were totally rebuilt and have larger than stock intake and exhuast valves (can't recall the size) and were ported, manifolds matched etc.....
BTW, FAT has been great to deal with, nice people, very helpful.
I expect the issue is simpler and more basic than carb size, (I would hope so!) at least I will be certain to eliminate the possibility fuel supply problems before going further. This setup worked fine with the previous engine but sat for several years.
Have not had a chance to run again with revised fuel system, but will hopefully tinker this weeekend. I have a 3.5 psi vane type pump, will run without a regulator but will rig the gauge and watch what happens.
Have some experience with webers - last engine had 42DCNFs, I rebuilt a set from a maserati merak, jetted, synched, setup myself, am well acquainted with the basics, though I am hardly an expert.
Will re-read the weber books I have for "first principles" on fuel supply, (just in case) but the question was asked hoping to get some opinions from those (like John Rogers) who have thoughtfully built and learned from track cars, without budget as the first priority.
Thanks as always, going to dig out the weber books.
Dave
-- Dave
pics at
http://www.syer.net
Old 04-17-2012, 07:22 PM
