Anti-sway bar bushings
Say, I need to get some new bushings for the top connection of the ~ 8" link between the a-arm and the sway bar arm. this sway bar is aprox. a 22/23 mm bar it has a hollow sway bar arm. Components are zinc cromate (Gold) color. The "circle that holds the needed bushing is aprox. .75"dia and aprox. .6" deep. The bushing had a steel sleeve that the bolt went through. can anyone help me with a supplier?
thanks,
Old 06-26-2012, 03:05 PM
racer's Avatar
Weltmeister?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 06-26-2012, 04:40 PM
Yes, Weltmeister sells them the part number is PB-1013 I just ordered these pelican parts at the moment doesn't have them there getting more in a week but pargon-products.com has them in stock because I just ordered a set for the front of my 914 yesterday. And the name of the 8" link between the a-arm and the anti-swaybar is called a drop link.
Porsche 911, 912, and 914 Weltmeister Restoration Factory Sway Bar Drop Link Bushings with Sleeves.
Pelican Parts - Product Information: PB-1013
Old 06-26-2012, 07:28 PM
racer's Avatar
Curiously, I had a 914 with a weltmeister rear sway bar, of unknown vintage. Sadly, a bushing failed on the droplink. I saw that someone still sold bushings and ordered some. Sadly, when it arrived, they had changed the bushings inside dimension. The metal sleeve to go around the bolt was of a different dimension. Just a warning.. Not sure if you may have a similar issue or not.
Past:
Old 06-27-2012, 04:53 PM
