Distributer change ?
Presently running 2 Weber 36 dcnva carbs on the 1800 and German made 009 with Pertronics many say these have a better advance curve than the other 009's (Brazilian and chinese copy),however its seems a vacuum type will be better ?.
The Webers are fairly well "'dialed in" with good idle and power but a have a dead spot with feels more like ignition that fuel. I still think its not running as it should ,I have a good vacuum one which I want to try ,the bosch number is 0 231 170 093 ?,research indicates it was used on a type 4. Is there any set rule for vacuum pick-up off the webers, for example do I use 1 or 2 vacuum ports off one carb ? Thanks in advance.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
The distributors that had the vacuum pots were meant to retard the ignition for smog purposes, the advance side was just there. It is true that the 009 has crappy advance as it was initially made for "stationary" engines so advance was never an issue. Having said that, if the car is a track/auto-x/race car then total advance is what you are concerned about so keep RPMs high enough and the advance will not fall off. If it is a street car then the curve is important and there are some that are much better. In any case I would only worry about mechanical advance.
Thanks John, mine has no retard port reckon its off a carb motor,any idea's on the vacuum supply as per my thread,know what you are saying about the mechanical ones,the original 010 cast iron body type was an industrial motor one also,good for drag motors
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. Last edited by porschetub; 03-19-2013 at 02:06 AM.. |
Hell Belcho
Your carb is off an VW Bus with fuel injection. I'm gonna guess that the advance curve wont work well with those carbs. Try to find an 050 distributor. Bosch no. 230 081 050.
Saved by the buoyancy of citrus. Last edited by Nostril Cheese; 03-14-2013 at 10:42 PM.. |
So I'am guessing its off the later fuel injected motor as it has no vacuum retard or injector points plate (Vanagon perhaps) ???.
Hell Belcho
Yep, AFC
Saved by the buoyancy of citrus. |
ASE Master Tech - 35 yrs
throw away the 009 - does not have enuf advance -
get an 050 you can find more than 1000 vw-914 folks who will give you that advice
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
![]() ![]() ![]() I purchased sometime ago a collection of distributers on our countries best auction site ,won the best bid of $50 and got 10 good ones ![]() .Have been thru them and found a few suitibles,have one set up with hot spark ready to fit will report back,cheers.
