Rear 5 lug Hub kits?
Has anyone bought some of the 5 lug conversion kits out there? I am getting ready to but someones and would like to know if anyone has had good or bad luck using them.
I have my 911 frontend and just need the rear now. Thanks
Kerry (Back on the road, sort of) 914-6 in the Werks |
I guess I bought a "kit" as I called up another vendor who said they would sell me everything I needed. Hubs, bearings, 914/6 discs... worked out fine going in.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
I just bought a set of pre-machined rear hubs from GPR. $30/ea. I bought the studs and bearings from them too so they pressed the studs in for me for free.
Did they ask for your cores ?
I have been planning a "package" with HPH but wondered about a core charge. B |
The core charge was $100.
I bought them from the GPR too, with a core charge of $100. If you are using the later style hubs you need to tack weld the studs to the back of the hub. There isn't much metal for the splines to grip to stay locked.
Geoff |
I was looking at GPRs "kit". Do you need a special tools to press the studs in? I wasn't aware (informed) of the free stud pressing by them?? Can this be done with a vise or BFH (Big F Hammer)?
I am having one hell of a time getting my hubs out. I destroyed a socket getting the large nut off the hub. WOW !!!! Thanks
Use a impact type of socket and a breakerbar atleast 2'. Then jump on it or use a piece of pipe over the bar to extend it. Lots of PB Blaster too.
Cost me $20 to have the studs pressed in by a machine shop. I wouldn't use a BFH to bang them in. Use the BFH to beat the wheel bearings out though....haha great fun taking those out! Geoff
RETIRED
Use a wheel.....insert the studs into the holes, place onto the rear of wheel and snug up the nuts.....then use an impact wrench to pull the studs tight......save 20 bucks.....
Nice!!!
I like that idea. Did/do you still need to spot weld them on the back side of the hub? Thanks
RETIRED
No need to spot weld....IF the machining is good. The studs have splines to keep them from turning.
Also don't be afraid of late hubs. Never had a problem with breakage with them. I had a set of late hubs on a 200hp+ 3.0/6 914.....MANY burnouts.
I was going to say ... I've never heard of a hub failure using a late hub.
I used GPR for a complete kit. Core was $100. I did notice that the rear hubs were drop shipped from Perry Keihl9 (sp?). Maybe you can skip the middle man and save a few bucks.
Carlos 76 2270 |
Too funny about the drop ship.
I know where Perry gets them from, I'm kinda surprised that Dave Shepard (GPR) didnt have them in stock when he "sells" a kit. B |
I got a set of hubs and work done by rich johnson. the core charge was only $30 I believe.
RETIRED
A retailer is only as good as his machinist.....I ordered some drilled rotors, damn things took three weeks on a "rush".....I bet GPR was back ordered and handed the order off to PK....
Derek,
You bought from the person who supplies everybody mentioned in this thread. Rich does them in batches of 20 sets. B |
Oaky, how do I get ahold of this Rich person ( No pun)
Unregistered
VA914 wrote:
"Has anyone bought some of the 5 lug conversion kits out there?" Why, are, you going to copy them and pretend they are your idea? Last edited by sammyg2; 08-03-2002 at 06:59 PM.. |
