porschetub's Avatar
914/6 engine bay tin
Is the early 911 engine perimeter tin the same as used on the 914/6,seems that way but need to ask before ordering,thanks
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 08-03-2014, 10:03 PM
A914Guy's Avatar
914-6 Engine Tin
The five 914-6 engine sheet metal pieces are unique to the six. None of the 911 engine sheet metal pieces are the same as the 914-6 pieces, nor are any of the 914-4.
I'd suggest buying a good, steel reproduction set.
Good luck with the project!
Rich
3.0L 914-6 Conversion
Old 08-04-2014, 05:52 AM
porschetub's Avatar
Rich
Thank you ,which replica set is best ?some look a little rough,cheers.
Old 08-05-2014, 01:03 AM
A914Guy's Avatar
914/6 Engine Sheet Metal
This set is an excellent quality steel set. It requires screws/nuts to mate each piece and if you have heat, you would open the two side pieces for the air hose.
I suggest powdercoating each piece because of it's durability but you can paint these if you prefer.
The sets retail for $400 > $450. I have a couple sets available if you are interested.
Old 08-05-2014, 08:48 AM
porschetub's Avatar
Thanks got your PM ,hadn't read this reply so ignore my request for pricing,and cheers
Old 08-05-2014, 02:15 PM
