Va914's Avatar
A/C compressor with no Refrigerant
Is it okay to connect an A/C compressor (belt only.. no power) up and run the car around?
I have not made hoses yet and will cap the connection to the compressor. The belt WILL be installed but no power to the compressor.
Sould I also change the refigerant oil in the compressor before it is connected to the engine?
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 10-29-2002, 11:09 AM
JWest's Avatar
You can run the car just fine.
Old 10-29-2002, 11:32 AM
Va914's Avatar
Cheers
914-6 in the Werks
Old 10-29-2002, 11:48 AM
sleepdoc's Avatar
compressor
Hi
This is no problem because without power the AC clutch just spins free and doesn't turn the compressor.
The compressor will get flushed when you get the new system charged.
best Mark
Old 10-29-2002, 12:14 PM
