-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   My 1990 S2 Cab Project thread (http://forums.pelicanparts.com/showthread.php?t=1019264)
azbanks 01-18-2021 09:55 AM
Hot tanked
http://forums.pelicanparts.com/uploa...1610992441.jpg
Media blasted and wire wheeled
http://forums.pelicanparts.com/uploa...1610992535.jpg
azbanks 01-18-2021 09:59 AM
I am trying to decide if I want to leave them-semi polished or if I want to powder coat them. I already powder coated the sway bar and hardware.
http://forums.pelicanparts.com/uploa...1610992755.jpg
azbanks 01-26-2021 09:03 PM
The block is being sent out to be bored and nikasil coated. The pistons are going back to Wossner to be re-coated for the nikasil bores.
jjeffries 01-27-2021 05:27 AM
Banks, who does the Nikasil ... Millenium?
Best, John
azbanks 01-27-2021 09:27 AM
Best, John
Yes, I am sending it off to Millenium on the recommendation of Karl at Racers Edge. I picked up the Wossner S2 Turbo pistons through Karl.
azbanks 01-27-2021 02:00 PM
I'm looking for suppliers for valves that can handle the heat of the turbo. I found some SS valves but I was hoping for sodium filled inconel exhaust valves.
I found a supplier who will make me what I need for a decent price per valve.
The problem is that they have a 100 piece minimum for custom orders. What am I going to do with 92 extra valves???
azbanks 02-12-2021 09:36 AM
A few minor adjustments and this is off to the waterjet.
http://forums.pelicanparts.com/uploa...1613151361.jpg
azbanks 04-16-2021 03:56 PM
The 944 is up on jackstands. I need the jackstands to drop the engine in the 914.
What to do, what to do?
Have custom stands built for the front of the 944.
http://forums.pelicanparts.com/uploa...1618613804.jpg
azbanks 04-16-2021 04:18 PM
Does anyone have the specs for pinion depth and pinion preload fro an AOD transmission out of a 1989 944 turbo?
I need the whole spec sheet if anyone has it.
culture 04-22-2021 09:05 PM
AZ. You have come an incredibly long way. I'm sending you a PM. Look fwd to catching up.
azbanks 04-22-2021 09:37 PM
Getting even closer. These came today.
http://forums.pelicanparts.com/uploa...1619152590.jpg
http://forums.pelicanparts.com/uploa...1619152637.jpg
azbanks 04-23-2021 01:28 AM
The Pistons came back from Wossner 4 days ago.
1990 944S2 Cab 05-08-2021 05:44 AM
Nice post, my car is very similar and also white. I found it much easier to replace the fog/driving lights with a plug in HID system and use them for driving instead of messing with the headlights
azbanks 05-08-2021 02:22 PM
My plan is a one piece header panel. I want to get rid of the gaps/lines for the headlight openings.
None of my plans end up being the easy way.
azbanks 06-07-2021 06:11 PM
My fuel rail and a few other things are anodized blue. Is it a bit overboard to order custom blue anodized nuts, washers, and bolts to match?
http://forums.pelicanparts.com/uploa...1623114658.jpg
azbanks 09-12-2023 03:12 PM
Buying/remodeling a new house, kids in college, etc have significantly delayed my progress on this. The engine rebuild will not be done for a while so I bought a stock replacement engine.
I've got to get it done in time to road trip to RSR.
azbanks 09-21-2023 11:51 PM
Progress.
Buying a used engine can be a crap shoot.
This engine showed up covered in oil and grime. The area that was under the bell housing is how most of the engine looked when I picked it up at the freight terminal.
http://forums.pelicanparts.com/uploa...1695364000.jpg
I bought it from a reputable seller and he said it was a running engine so I will take his word for it. He never said it was a clean, running engine.:D
I am not disparaging the seller, he sent me exactly what we discussed. It's condition is fitting with the mileage it has.
Two extensive power washes and a lot of time with a brass brush and it looks half way presentable.
http://forums.pelicanparts.com/uploa...1695365174.jpg
Going a bit overboard dressing it up. These were parts I was collecting/creating for the turbo engine I will be putting in it in the future.
The one thing that bums me out is that no one will see my uber-fancy bolts when the engine is in the car. http://forums.pelicanparts.com/support/smileys/sad2.gif
http://forums.pelicanparts.com/uploa...1695365304.jpg
http://forums.pelicanparts.com/uploa...1695365343.jpg
Now I have to get it all back together and I hope to have it in the car by end-of-day Saturday.
GovernorModr 09-28-2023 08:11 AM
azbanks 09-28-2023 08:25 PM
Doing that won't get rid of the headlight cover gaps. That has always been my plan, to create a one piece header panel that does not have any gaps ans just looks cleaner than the factory three piece header panel and light covers.
GovernorModr 10-02-2023 06:59 AM
