-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   How fast does it go? (http://forums.pelicanparts.com/showthread.php?t=10538)
jody 04-25-2000 09:00 PM
I've only had my car to 125 mph. I think thats all it will do.
How fast is Your 944?
I stop a 150 mph in my vr4. ( it doesn't want too. )
Mine is a 1983 NA
Pilot_951S 04-25-2000 10:08 PM
I've had my 951S upt to 163MPH she had a lot more but I can never find a piece of road straight enough or with a small enough amoutn of traffic on it to get it maxed out.
Also had my S2 up to 155 when I had that car.
1.2gees 04-26-2000 05:48 AM
I remember going a tad over 145 with my modified 84 2.5 NA, but after turning it back to near stock, it wont push over 137 indicated mph.
lm6y 04-26-2000 05:32 PM
140 mph flat to the floor, on pump gas. Getting ready to try some avgas to see if it helps. Come to think of it, that was when it was bone stock, and I've played with it since then, so who knows.
Harp 04-27-2000 05:39 AM
163 MPH on the street/public road? You are braver than Rambo. Aren't there occasional bumps that could toss you and your car into the woods?
As to the other post about using avgas, doesn't that have a tendnecy to burn up the engine, valves at least? I think I'm recalling correctly, otherwise everyone would do it all the time because I have heard it can provide a significant power boost.
divezic 04-27-2000 07:43 AM
I got my 84 to 130 and still had a little more to go...
Watch out, AVGAS usually had lead which will wreak havoc with the cat converter.
Pilot_951S 04-27-2000 02:28 PM
harp,
No bumps when you are flying low!
1.2gees 04-27-2000 04:12 PM
The late 944 NA speedo is optimistic by 10% exactly at 100mph, and the early is within 1%, don't know if this applies to 951 or S2. The reason to this was the redesign at 85.5, Porsche didn't get any hp out of the engine after lots of mods (to increase reliability, and decrease maintenance really, but still) but wanted the owners to feel as if it was actually a faster car...
lm6y 04-27-2000 06:21 PM
I was actually thinking about 5 gallons of avgas then filling the tank the rest of the way with 93 octane pump gas. As for the cat. converter, it kinda got lost when I had the 2.5 inch flowmaster exhaust put on.
I have to agree with the pilot, fly low, no bumps, and under radar! I'm not saying go out and endanger yourself or others, but, if you get a chance, go out and fill the prescription for speed that Herr Doktor ordered, and REALLY see what Porsches are like in their element. You won't regret it!
jody 04-27-2000 06:41 PM
Thats fast, maybe my engine needs to be rebulit.
As for avgas it will only help if you have the compression needed to stop detonation of high compression with the time advanced. That's a Fact.
As for speed everyone knows a good place to let it go. Me, its on a road less traveled and is very smooth. ( why own a car like this if you don't drive it! )
My 2 cents
thamlin000 04-29-2000 03:20 PM
I've never gone over 110 mph in my 83 944. It has more left and it feels very stable but I'm too afraid of speeding tickets (or worse, reckless driving tickets). I'd rather hit the curvey backroads and do some 2nd-3rd gear sprints.
1.2gees 04-29-2000 04:25 PM
I just got arrrested in virginia for going 136, I have 95mph written on the ticket, I'm going to court on May 30th, I'll let you know, I'm going to juvenile criminal court, so it might be serious, but I've asked my lawyer, he says since it wasn't in my homestate, they can only take my privelage to drive in VA, and they probably wont even do that, just a (big) fine. Again I'll let you know.
Ahmet
85944na 04-29-2000 04:46 PM
the car should definetly go more than 125, 135 minimum, probly top out at 137 like 1.2 said
Pilot_951S 04-29-2000 10:11 PM
Ahmet,
Juvenile court rules, did you know that you can have your record expunged after you turn 18! Also nobody can get into a juvenile offenders file after they turn 18 if the file has been sealed.
Anyway they probably aren't going to do anything major to you, if they were going to they would have arrested you.
When I was 18 (damn am I getting old) I got caught doing 103 in a 55 and I did get arrested, still all I had was a $1200 lawyer bill (ex cop, I love that guy) and a $500 fine to pay cause I pled youthful offendorship staus. Oh and I had to get my car out of impound ($60) and I had to go to court like 5 times.
1.2gees 04-30-2000 11:17 AM
I hope I don't have to go to court more than once, since this is not the state I live in...
Thanks for the info Pilot
Ahmet
Lawrence Coppari 05-02-2000 02:11 PM
Careful with your speed claims. The speedometers are wrong in 944T's. Mine, with the stock 225/50-16 wheels registers over 7% high. A 225/60-16 corrects the error.
Pilot_951S 05-02-2000 02:24 PM
How's this:
The speedo was reading 163 MPH in my 951S, Also I did this on my 17" wheel and tire combo which is just slightly larger in diameter than stock.
http://www.miata.net/garage/tirecalc.html
Also how do you know that your speedo reads high?
Lawrence Coppari 05-02-2000 02:30 PM
A 225/60-16 tire/wheel combo stands 1.77 inches taller than the 225/50-16. You need a big correction to get the speedo correct.
Pilot_951S 05-02-2000 05:30 PM
Once again how to you know that the speedo is off?
1.2gees 05-02-2000 09:44 PM
A taller wheel/tire combo than stock, will decrease the reading, not increase it, I recall reading about the speedo in a book named "944, the gold portfolio" which is really a collection of magazine articles about this car. (more than 100 of them) I remember that one of them tested the top speed by radar, as well as the 0-60 times, and concluded that the late type speedo was off by around %10, starting at less distortion at 40, increasing to around %10 at 100, I'm not sure how far it'll be off by over that, not even sure if the turbo speedo is off at all, they also noted that the early speedos were within 1%.
jody 05-03-2000 04:14 AM
You could always check the odometer against a mile marker or 10 mile markers for a better idea as to how far it is off. You could run the car up to 60mph and use a stop watch. The car should pass a mile marker every minute, or 120mph and a marker every 30 seconds.
Pilot_951S 05-03-2000 09:34 AM
1.2, Jody,
Thank you.
I am however still curious as to Mr Coppari's evidence that all 951 speedos read high.
In any case it doesn't really matter, I was cruising along at an indicated 163, I'don't care if there is speedo error I was going damn fast. Besides what am I going to do buy a radar gun and try it again?
Still 7% is a large error and I want to see some evidence. Besides which 1.2 you say the speedo was pessimistic by 10% at 100?
Lawrence Coppari 05-03-2000 01:38 PM
I only get to read this at night; hence, the delay in the reply. Where I live there is a measured 2 miles that agrees with I-81 markers. I use a stop watch and keep the car as close to 60 as possible. That is how I determined the error. As an aside, I have another sports car, an 87 of different make but still European. Coincidentally, it is off by the same amount. May car is a 1986 944T with a considerable amount spent on engine upgrades. Upon first completing the first of the upgrades, I tested the acceleration from 70-100, both directions on flat ground and noting temperature because that is significant with turbos. The result was unbelievable acceleration. The thing is fast but not that fast - I was comparing it to C&D testing of fast cars from 70-100 and looking at hp/torque ratings, rpm range, and weight. Furthermore, I drive it at a lot of PCA driver school events with friends who have similar cars. Their turbos are all off just like mine with stock size tires even though they are racing tires. That is why I made the statement. I did refer to the 944T when I wrote what I wrote.
Pilot_951S 05-03-2000 02:16 PM
Thank you
Now did you happen to check your odometer reading against the measured mile? The odometer works off the speedo so it will also be 7% out of whack with the measured mile if your speedo is 7% off. This is more accurate than hand timing the mile and attempting to hold 60 mph, and is repeatable at any speed.
Just intuitivly it seems rather odd that every european car would have a 7% speedometer error as standard equipment.
Lastly anybody know if the 86' 951 had a speedo cable to the front wheel or is it electronic and in the transaxle like my 88'?
Lawrence Coppari 05-03-2000 02:40 PM
Of course I checked both. Both cars' odometers and speedos are off about the same amount to the high side. I think sports car manufactures used to cheat on their speedos or they changed tire sizes without correcting the speedos and odometers. I'm not saying yours does not go that fast; I'm suggesting one cannot believe what one sees on a speedo. Do you know how to determine circumference or diameter of a tire from the tire nomenclature?
Lawrence Coppari 05-03-2000 04:50 PM
I have two other German cars besides the 944T. One reads about 3% low at 60 while the sedan is pretty much dead on. The former has a cable; the latter is electronic. My Italian sports car reads high like the 944T being only slightly off when cold but reaching about 7% off when used for 20 miles or so. Both are electronic.
Pilot_951S 05-03-2000 06:02 PM
You can not accurately determine tire circumference or diameter from the nomenclature, however I do know how. Anyway it is irrelevent becuase tire manufacturers are allowed a 5-7% leeway in the acutal dimensions of a tire. (oddly enough I spoke to a Michelin engineer last week about a different topic so I've got more tire knowledge than I know what to do with right now)
Anyway it wouldn't do you any good to calculate tire dimensions, you are better off with a tape measure.
Lawrence Coppari 05-04-2000 03:07 PM
Well you have gotten me curious about how close I can compute diameter(circumference) from the nomenclature. I have 4 vehicles with tires from BFG, Michilin, Goodyear in several sizes. Some are even R1's and Yokahama A032's for track use. I'll get to it this weekend if things get a little boring. Actually, I have oil changes on two vehicles to do so the things will be off the ground anyway. I will let you know what I learn not to prove anyone right or wrong but just for the sake of information. Probably will come up with some sort of table.
jody 05-04-2000 06:20 PM
Man what a subject. My tire's are said to have the factory size. At least thats what the guy at http://www.tirerack.com told me.
I think I'll check the speed this weekend, just for fun!
sqgabriel 05-05-2000 01:02 PM
being in the uk i think i can answer the 7% error part, unofficialy the police in the uk allow you to be 7% over the speed limit before issuing a ticket, wonder if this helps
(policeman 83 944na)
Mac 05-06-2000 09:04 AM
Driving my 86' 951 ,I to thought the speedometer was incorrect , so I compared it against a 96' Vette that I was following to a track event using portable radios.
My findings was the 7% high readings. Here is the puzzling part,when I tested against the mile markers, the odometer was right on ?
Finally using the construction signs that also read your speed it confirmed the 7% error. The speedo on my car is electronic driven off the trany.
Pilot_951S 05-07-2000 04:31 PM
Oh well, looks like I'll bhave to gut my car and replace the gauges.
thamlin000 05-07-2000 10:22 PM
1.2, sorry I'm so late to reply. With my luck, the one time I do a top speed run, I'd be caught. Last year I got a 90 mph speeding ticket and the cop told me that if I'd been doing 95, that would be grounds for wreckless driving. Luckily the ticket was dropped after I attended a defensive driving course. Hopefully the courts will be sympathetic to your case. Good luck with the courts.
1.2gees 05-08-2000 11:39 AM
Thanks, well, I can only hope it won't cost me more than a couple of $100...
Lawrence Coppari 05-08-2000 02:54 PM
Tire nomenclature and circumference. I did not do all the tires I intended, but what I have done gives me confidence that the circumference (diameter) can be computed from the nomenclature.
If there are two numbers in Measured Column, percent diff correspond in order.
Size Computed Measured Circ Pct Diff
225/60-16 83.66 83 ¼ 83 ½ -0.49 -0.19
245/45-16 77.54 76 ½ * -1.3
225/50-16 78.09 78 ½ 79 +0.53 +1.2
195/65-15 78.48 77 ¾ 78 -0.93 -0.61
* Tire has no tread remaining
Robert MccRiley 05-15-2000 01:57 PM
I have a GPS in my 944 witch dispays my speed using sats, and I've lernd that the speedo is not acurit at all, below 40mph the speedo reads slow, around 45-50mph its about on, at 55mph the speedo reads 60mph, at 65mph it reads 75mph, at 70 it reads 85mph, thats about as fast as I go these days "getting to old fore a pocket full of tickets"
jwn 05-23-2000 04:17 PM
I believe the advertised speed was 137mph with the headlights up, 143 with the headlights down. I too have a GPS and have done some testing, has everyone found with a 5 speed at 3000rpm in 5th gear to be doing 80mph? (My 83 944na speedo, GPS and tach all seem to agree here)
p0r2chby 05-26-2000 01:56 PM
I have an 86 na. This morning I did the 5th gear, 3000 rpm test. My speedo showed 83 mph. Am running 235/60 15's in back.
redp944 06-01-2000 01:36 PM
I just got a speeding ticket...thank god the cop didn't see me when it was really wound up! My girlfriend wanted to "go fast"...the car can do that, so I did. We took a quiet country road into town at night with hills and bends. Somewhere along I passed a cop without noticing - he claimed he clocked me at 70. Fine, I said because I didn't remember going that slow. All I remember is I passed a car, then rounded a corner and hammered the accelerator to top a hill at 95 (giving a great negative G effect), then round a sharp corner near 75 to head into town. According to the cop he couldn't keep up in his Crown Victoria around the curves and up/down. I completely lost him. He caught me because I didn't realize he was back there at all. A mile after the hills and curves end is town. I saw the lights coming, so I just pulled over and waited. He was particulary cool about the whole incident, and it only set me back $80.00. I would have hated for him to see me top that hill though.
Lawrence Coppari 06-01-2000 02:00 PM
The speedo reading is independent of tire size. It just measures how fast some output shaft is turning. It doesn't care how fast the car is going.
