968 Shocks/Struts Questions
I have a 93 968 that I looking at doing some winter maintenance with. I have just finished oil/belts/coolant/brake fluids and started looking a the shocks and struts. I'm not sure they need attention. I do not see any damage or leaking oil. The bump stops do show some wear on the struts but that's it. The car has 55K on it. Should the shocks and struts need replacing? I don't track and the car is just a Saturday/Sunday top down driver for me but I would like to keep everything in good shape.
If I do need to change any recommendations? The OEM struts are still available but the rear shocks are not. It looks like my options are OEM struts with Bilstein rears or Koni front and back. Any other non-track options?
Old 11-10-2020, 02:15 PM
Are you having any issues or complaints about the ride quality? Most people switch if they want stiffer/sportier handling.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 11-10-2020, 02:45 PM
Ernie944's Avatar
Is your car a 968 Coupe or Cab?
Caraquet,N.B. Canada.
Old 11-10-2020, 04:46 PM
racer's Avatar
and is your car M030 equipped or not?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 11-11-2020, 06:10 AM
> "the car is just a Saturday/Sunday top down driver"
Probably a cab and probably not an M030 car.
At 55K the shocks and struts are fine, you would not notice a change if you replaced them. Unless one is damaged, has leaked, etc. The stockers are IMO remarkably robust and long-lived.
-Joel.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 11-11-2020, 11:48 AM
Yep, 93 cab non M030. I have had the car for about 20 years but its been in storage some of that time while I was working in Asian.
Old 11-11-2020, 02:41 PM
Ernie944's Avatar
-Joel.
+1 they should be good for a while,but still you could start looking around for the rear shocks ,they will be hard to find,none list here on Pelican,lots of them for the coupe but none for the cab.
Old 11-11-2020, 03:59 PM
I did my 92 in 2016. Only 75K but 24 years. Made a world of difference. After going back and forth, I ended up putting the OEM Boges (Sachs??) back on it. Couldn't be happier.
David #476
'78 911SC (gone home to the Fatherland)
'92 968 CAB
Beck Spyder #201
Too many bikes to list
Old 11-13-2020, 10:15 PM
i thought the koni rears where a little much on my 92 cab and went back to OE.
check jason as he shows them listed
Old 11-14-2020, 05:10 PM
