944NA Throttle Body Bore - How many mm?
I have a spare 944NA throttle body that was on my 84 Drivers Ed ride at one time. I know I had a enlarged , bored out one , but Im not sure if it was on the car when I sold it.
The bore on this one is 60mm. Is this the stock bore size? Thanks in advance., Pat Leber
Patrick Leber 2001 540i Sport / 6-speed 1983 Porsche 944 Club Racer |
Im not sure but Im sure someone will chime in, I would measure mine but I hand ported mine, So Im not sure what is.
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
the number 57 mm comes to mind as stock...but don't quote me on that one.
Rick, Chatsworth, Ontario, Canada 1988 944S 18" 993TT wheels Magnaflow hi performance exhaust K & N air filter and MaxHP Kit chip |
Redline Racer
I don't know what the size is. All I know is that it's bigger than the openning on the end of the stock intake snorkel, which is why I detatched it.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Well, I port matched it to the intake manifold which took a lot of work, I also took out the ridge that is cast into it and made it smooth, Then grinded down the rod in the center for better flow. It was me being bored and messing around Before I rebuilt it.
![]() ![]() ![]() Still gotta do a little polishing, Also sorry for the bad pics, It was taken with a cell phone. Again not sure if its gonna make any difference, Just me playin around I'Ll take some better pics soon
Redline Racer
Ah, yes..you reminded me that I did port match mine as well (for me it was waiting for the RTV to set after cracking open the AFM for cleaning). At first with a file, and later did a better job with a dremel (much easier). I did grind and polish the ends of the throttle plate screws flush with the shaft as well. I thought about smoothing the step on either side of the center section where the throttle closes, but haven't done that.
![]() ![]() Now what would be cool if I had a method of calibrating it would be to modify a stock AFM by reducing the aerodynamic profile of the door and proportionally reducing the spring tension so it gives the same readings with much less spring resistance that has to be overcome, decreasing the restriction. And get a cylinder head and do a custom port and polish job, and, and... I've done a few small engine heads with actually some very pleasing results, a OHV Suzuki lawnmower motor, a 16.5hp OHV briggs motor, and most fun of all...a Honda XR150 dirt bike motor. The bike was a totally different ride with the "new" head, and I also polished the carb, piston crown, and port matched the carb, intake boot, and cylinder head port. Hard work doing porting work mostly by hand, but it ran really well. I am a little surprised with the kind of sloppy fit and finish with the casting work, ect. for the bike and even the TB/manifold on the Porsche. I guess mass produced stuff just doesn't come out to high standards, and the expense is not worth the small gains for mass produced machines. I didn't expect much with the mower engines though...and there was much to be desired in their stock form They soon became the most unstoppable mowers I've ever ran. I'm dying to P&P a 944 head. It would be a huge project, though, since it is x4 and they all need to be as identically done as possible. I like to feel like I did something out of the ordinary that makes my car a little bit better/more unique than a plain old stock sample, even if you can't see it.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 12-15-2007 at 10:06 PM.. |
WOW, that polish job is sweeet. Yea I was very surprised on how the ports from the TB to intake are way off, Almost 1/4 of a inch overhang. I will get better pics when done, Im not sure what the step is for but I figure I will try it removed. That AFM idea sounds cool, Or you could just go MAF like I did.
![]() This is before the rebuild ![]()
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership Last edited by fast924S; 12-16-2007 at 12:28 AM.. |
Redline Racer
But the million dollar question...how much did the MAF setup cost? Is it possible to have a MAF with the stock DME?
I checkout the Gasket between the intake manifold and head, It matches good on both sides so Im thinkin the manifold to head is ok, really hard to see. The Maf kit is a old kit from Huntley racing, Got it about 4-5 years ago, it cost $1200, came with the MAf and tubing, Fuel controler, AFPR, and a short band a/f gauge. Its is running with the stock DME but it does have a piggy back 4 knob fuel controler from split second.
What other simple things can we do to boost VE Also what do you think that step is for in the TB
Redline Racer
As for the step, probably not for anything important, probably just a result of the casting dimensions giving some leeway for having to machine an exact bore size. I'd be sure to only smooth the step and not to disturb the dimensions of the central area where the plate meets the bore.
I agree, I think That step is for the machining of the bore for the plate, I made very sure I didnt mess with the surface where the plate seats. Im intrested to see how my engine runs after the rebuild with the JME cam shaft and other mods.
Besides the AFM, I think the next big restriction is the stock head, About a year ago, I ran a test with one of those PC dyno's That had all the info/demensions of our motors already loaded, It seemed to be very accurate with HP/tQ numbers, But I did notice from the data that the stock head with the stock cam/valve's just cant flow huge amounts of air to make alot more HP. The whole 8v with a single cam is the biggest problem, 16v with 2 cams is the way to make more power in NA form. But I hope to show some good dyno numbers with my 8v NA setup this spring
Redline Racer
A good porting job combined with a cam should pick up a few horses. keep us posted.
DEF. Let me know if you find anything else that needs porting polishing or boring ;-)
Redline Racer
Check the intake manifold gaskets for proper dimensions. Unfortunately, this is probably only really possible to do well if the cylinder head is dismounted and the valves removed, but if you happen to be porting a spare head anyway, might as well pick up a spare manifold to match to it.. I've seen so many gaskets that are cut a tad smaller than the actual ports, or cut off center. Why spend 20+ hrs porting and polishing if a stupid piece of paper is hanging out into the air stream? They should be flush for best results. Too large is not good either, since it creates a ridge that will probably cause slight localised turbulence, but not nearly as bad as too small. I had to trim the AFM to airbox gasket so it didn't intrude on the airflow.
What really needs to be done is the inside of the intake manifold. It looks like crap in it's stock form, but it's so enclosed, I have no idea how it could be done. Not to mention it is sooo bad, it would take forever without some kind of thing other than fingers and sandpaper. It would probably be easier to just fabricate a custom one that isn't cast using pine cones. Or retrofit the tuned manifold used in the 968 by cutting the stock one just before the fuel injectors and welding the 968 part, which would also be apropriately trimmed to fit.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 12-16-2007 at 09:06 PM.. |
meister member
You could always extrudehone the intake manifold.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
dallas911
Need BORE old thread....
Anywhere in CA I Can Bore my 1991 NA 944 S2?
Called a Few places , Nobody's Calling Back, Not at working..... |
I had a 944 NA throttle body done by these folks a few years back. Quick shipping, reasonable price, etc.
Maxbore.com throttle body boring service and repair Before anyone asks, no, going to a 60mm throttle was not worth any power at any RPM on an otherwise stock 944 NA 2.5L engine. But I would bet there's some power to be gained on a 3.0L 944S2. |
dallas911
I'll let you know how a 3.0 Does on Dyno, Tune Is: KN Filter, TB. FVD Chip (not steve Wrong) High Flow Cat that's Emission Friendly.... |
