Question Wheels turning
Ok i have a questions its probably nothing serious but i figured i'd ask to cure my curiousity.
I have my car on jack stands with all the tires, rotors and calipers off (doing a brake job). I start my car up with the car out of gear and my back wheels are turning but you can stop it with your hands or when you push the clutch in it spins faster. I think i just need to bleed/flush the brake/clutch fluid or am i totally of base with this one?
The problem is on my 93 968 any advice would be greatly appreciated.
Thanks,
Ken
93 968
91 944S2
Old 05-28-2003, 10:12 PM
Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
Is it both tires that are spinning or just one? Also, when you stop the one, does the other spin faster?
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 05-29-2003, 12:54 AM
Send a message via AIM to TheCooler
Tires shouldnt turn when you take it out of gear because uhm ...its out of gear. They were probably spinning since you had it in gear before. the tires should spin when you let the clutch up when its in gear. Maybe you let the clutch up some when it was in gear then pushed it back in and then looked at the tires again.
IF this did not happen ...check out your tranny and clutch because something is wrong. I dont know what your doing but i hope its nothing bad.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-29-2003, 04:04 AM
AFJuvat's Avatar
tires spinning while off the ground and the vehicle is in neutral is completely normal.
rotational mass of the transmission is still spinning, even while the car is in neutral - just very slowly and without much force.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-29-2003, 04:53 AM
the oil between the gears and bearings act like a viscous clutch.
Steve Frew
'86 951 Mostly stock and all fun!
Old 05-29-2003, 10:35 AM
Ah ok thanks for all the replys i won't worry about it then. Car is back on road with new rotors and brakes and the tires are on order. Just need Scott R to get back with me so i can get the control arm from him to fix my clunking noise.
Ken
93 968
91 944S2
Old 05-29-2003, 05:01 PM
944TurboRacer's Avatar
Bernoulli strikes again!
(Fluid mechanics engineering joke)
Old 05-31-2003, 01:04 AM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
would that be Bernoulli's theory/method?... heheh good call..
My car is naughty
Old 06-01-2003, 08:36 AM
