Sjoeyp's Avatar
Engine Harness 2.5/2.6 compatibility
Will a 2.7 engine harness work on a 2.5 motor from a 1985.5 Base?
Both are manual and it appears that the DME has the same 35-pin connector
Old 08-28-2023, 05:13 PM
I sorta think the 2.7 uses the S2 flywheel and single crank sensor. You could check PET to confirm.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 08-28-2023, 07:36 PM
