Post 924 Grease Questions
We are in the process of replacing the clutch in our 82-924 (among other things!). The book (Haynes) says to use MoS2 base multipurpose grease for all rubbing surfaces. What is MoS2 grease? Can any of you recommend a product by name that will serve in this application.
Also they recommend Lithium grease, NLGI grade 3 for the needle bearings in the flywheel. What can be used here? My parts store down the street has grade 2 Lithium.
And finally, the cv joints at the rear wheels require molybdenum. Who makes this product?
It took me so long to get this vehicle apart (that's a whole story in itself) and pieces are so expensive, I don't want to screw anything up by cutting a corner or using the wrong lubricant.
Old 03-07-2001, 11:51 AM
lm6y's Avatar
Post
I used Valvoline synthetic blend. Pick it up at Autozone for around $5.
Old 03-07-2001, 01:54 PM
Post
I've used the synthetic like Imfy in CVs. For the rubbing surfaces like where the throw out bearing slides, needle bearings on fork shaft, etc I use lubriplate but now I,m about out & have no source.
I think MoS2 is molylydium Disulfide so you can look for a grease that contains this.
drew1
Old 03-07-2001, 06:55 PM
Post
yeah i think its molybdenum sulfide
without the "di" since ionic compounds never have prefixes except complex ions in compounds like bicarbonate but moly is a normal ion
Unless di is an accpeted mistake
In molecular compounds ya use prefixes though
Old 03-07-2001, 09:19 PM
