944 A/C Compressor mounting
Help, I have 1986 944. The Alternator - A/C belt started squealing recently so I checked the tension: I found that the A/C compressor mounting bolts are ... MISSING, to my surprise. The front bolt is a M10x1.25 x 50, I thought the back bolt is a M8x1.25x50, but it doesn't fit/screw in. Does anyone know the size of the rear mounting bolt? Can't find in the forum threads....
use a mirror to look and see if its lined up. thats more likely to be your problem why it wont thread.
1976 911 1976 914 1986 951 |
45 = m10 x 1,25 x 50
47 = m 8 x 55 ![]()
Kuehl 1987 911 cab, modified https://griffiths.com/ |
ok, so the front bolt was threaded, the back not. I found that the back bolt was sheared off. I drilled the broken bolt and used an "easyout" to get the broken bolt out, then I couldn't get it aligned for nothing!! I finally fed a smaller, but close to size nail through to help me get this thing aligned. WOW! it's in, front and back. what a job
And, that was Slick
Thread Tools | |
Rate This Thread | |
