Looking for tool front strut 924 Turbo
Hi everyone, I'm looking for a tool to tighten the union nut on the struts. The Bilstein tool doesn't work because it's too small. The inner diameter needs to be 58mm and the stud spacing 48mm. Using pliers or a hammer tool will scratch the new parts. Does anyone have any advice?
Old 08-30-2025, 02:55 AM
924RACR's Avatar
Normally we just use a pipe wrench... but with new parts you want to stay shiny... I have used an adjustable pin wrench for such things, looks like vice grips (so adjustable for gap) and has pins on one side, tabs on the other... the tabs could work in this case... lemme see if I can find a link to an example...
Yeah, there are definitely a lot of options if you search on "adjustable pin wrench" - this style might be a decent compromise between cost and quality:
https://defender.com/en_us/groco-adjustable-collapsible-spanner-wrench-sw-2531
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 08-30-2025, 03:42 AM
924RACR's Avatar
This is like the type I have:
https://www.denniskirk.com/v-twin-manufacturing/clutch-drum-locking-tool-16-0992.p284663.prd/284663.sku
Vaughan Scott
http://www.924.org
Old 08-30-2025, 03:44 AM
I have used a rubber strap wrench, like this:
https://www.amazon.com/Toolwiz-Wrench-Diameter-Universal-Plumbing/dp/B0C2V1ZZN8
Good luck, George Beuselinck
Old 08-30-2025, 04:44 AM
Politically Incorrect
onZedge's Avatar
Spanner Wrench
Edek
'87 924S
'91 535i
Old 08-30-2025, 03:28 PM
I picked up an old pair of vice grps and a previous owner drilled through both jaws and weled in little hard steel pins. they protrude out the side of the jaws.
I can adjust the opening or distance between the pins. I thought it was quite brilliant.
Old 09-03-2025, 03:13 PM
Thanks for your message. I'm currently building a tool myself so I can tighten the nut to the correct torque. Thanks.
Old 09-04-2025, 12:48 PM
I was a little off, it was a cresent wrench they used. not vice grips just drill through the jaws and put the pins in so they protrude out the side of the jaws. then the thumbscrew sets the distance between the pins, maybe braise the pin in and Id use hard steel for the pins, you might use drill rod and temper it if you are so inclined. you cna buy stuff Im sure but it dint look like a difficult project to just make up in your own shop.
drill rod is easily purchased in about 3 foot lengths,in n=most sizes etric and standard. the metalurgy is such that it can be hardened but sold in the state whher it is still machinable. basically heat and quench, how hot might affect its hardness You dont want brittle.. I think you can heat it red, let cool heat to straw color quench in oil.
the one I saw he had machined down the pin on one side so it had smaller diameter pins on one side than the other.
if you didnt want oharden you might just press them in or maybe tack weld on one side to prenebt overheating and affecting the temper, then for that, start with a hardened pin. no tempering.
there is a bit of a sciuence to correct annealing and tempering but basically you heat and quench makes the steel hardened, too hard means brittle.
maybe just sacrifice an old cresent made by "husky" or similar, not your favorite "snap-on quality" one.
Old 09-05-2025, 09:21 AM
