Post shift light...
Anybody know if those aftermarket shift lights (like Autometer) can be used w/ stock tach? I want a shift light, but don't want an additional tach.
Old 04-12-2001, 01:17 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
No, I don't think you can run a light to the factory tach. If you want your shift light come on at a predetermined rpm (that you can adjust), you can't hook it up even after openning the tach. But who knows, maybe somebody started making shiftlights that'll bolt to anything. Call up autometer.
Ahmet
It's all the driver...
Old 04-12-2001, 09:26 PM
Post
951s don't have shiftlights (or automatic trans).
I want to shift just after I roll off the RPM peak, which is a ways below redline. By LISTENING, I run way past, into the fall-off zone of the RPM band...
Old 04-13-2001, 05:41 AM
Send a message via ICQ to PrerYDoG
Post
I was under the impression that the 951 kept its power all the way through to redline, and that shifting at redline was the optimal point.
Old 04-13-2001, 09:19 AM
Post
951S holds power till redline, 951 rolls off after mid 5K....
Old 04-13-2001, 09:46 AM
1.2gees's Avatar
Post
Change your wastegate, and shift at redline (as well as make power up to).
Ahmet
Old 04-13-2001, 09:51 AM
Post
Thanks, Shaun!
Old 04-13-2001, 10:01 AM
1.2gees's Avatar
Post
A universal shift light will not function with a 951 tach... I'm sure something could be made to work however. (this is what I remember).
Ahmet
Old 04-13-2001, 10:07 AM
Post
what about plumbing into the dealer flywheel sensor? (see broken sensor thread)
That would be easy, right?
Old 04-16-2001, 06:38 AM
