bold patterns and offsets
oh gurus of the board hosted by the fine purveyor of parts from pelican!!!
please, bestow thy knowledge upon me!!! what is the bolt pattern and offsets for 15" phonedials on an 87 944 and 944S? i sacrifice my first born for thine grace and wisdom!! |
bump
944 NA 5-spd, Red, 1987 - 2005 May She Rest in Peace 944 Turbo 5-spd, Black, 1987-present 70k miles |
Non Compos Mentis
All Porsches use the same bolt pattern, which is used by nobody else.
You have either early or late offset wheels, which are also the same between 911s and 944s. Your car has anti-lock brakes, so it has late offset wheels. Early offset wheels will stick out your fenders. Late wheels can be used on early cars with spacers. That's about all I've got to say about that. |
thanks for the info dantilla, but i still don't know what bolt-pattern it is.
i have seached the forums and i believe the offsets are 56mm for a late model 944 but i still cannot find info on the bolt pattern no one knows? i find that hard to believe here at pelican
bump
5 x 130
** 85.5 944 na ** All Beauty - No Boost for now...
thanks!
btw, Mutt, do you have a catalog or website so i may review the dash accessories you carry?
Sure, if you want to shoot me an email with the info on your car at:
mildwild@rochester.rr.com I will send you the info and color samples on the kits. ~Lisa
