Feelin' Solexy
Tishabet's Avatar
What does this mean?
I just got my car back from the shop, where I finally had my ABS system repaired. On the notes section on the receipt, the mechanic lists some problems with the car.....but when I called him to see what they mean, he is on vacation! So I was wondering if you guys can
A)decipher what he's referring to (as in, what part of what assembly am I looking at?)
and
B)can I fix this stuff myself?
Here's what is says:
"Needs power steering update" (does this mean a new rack?)
"Oil leaks @ rear cam carrier end cap"
"Possible leak @ cam carrier gasket" (Is the "cam carrier" the housing around my camshaft?)
"front cam o-ring leaking" (is the front O-ring the seal for the gear/shaft behind the distributor? I just changed my belts this past weekend and everything was bone dry, no visible leaks).
Anyway, some guidance on what this means and whether any of it might be serious would be very helpful. Thanks!
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 11-11-2003, 11:10 AM
Power steering update is replacing the old hose from the reservoir to pump with a different design.
Sounds like the cam box and seals are leaking, if you can do the timing belt, you can replace all the gaskets and seals. The front o-ring is between the cam box and front cam bearing housing (the bit the distributor cap bolts to)
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 11-11-2003, 12:07 PM
Feelin' Solexy
Tishabet's Avatar
Britwrench, you are a veritable fountain of knowledge. Thanks!
Know where I can find instructions on fixing this stuff? Is it covered in Haynes?
Grant
Old 11-11-2003, 01:23 PM
Let's go shooting.
Dark Skies's Avatar
Don't forget to ask for the new banjo fastener when you get that hose - they're now a two-piece unit.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 11-11-2003, 02:32 PM
