Manute's Avatar
Smoke in the front and other different questions
Hi you all!
I have a few questions,i expect you can help me.
First of all...is there any way to recharge the lifters of the rear hatch?I opened yesterday and it fell at my head!
Another thing...i have noticed i have smoke in the front after starting the car from cold...After about 5 minutes,it start expelling white smoke from the bottom...about another 5 minutes more it stops.It only does it when engine is cold,from one day to another...It smeells like oil,so i assume itīs a drop from a leak,that fall at the exhaust. I asked in the dealer and they say thereīs no problem,but i donīt like a car that seems burning when i start it.Itīs not spectacular,but annoying. Do you know where should be the source?
And the last thing,off topic...anyone has or know how to make animated 944 gifs? I want 944 and porsche gifs to my cellular phone.
Thanks one more time!
85ī5 951
Old 11-19-2003, 02:36 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
No, the pneumatic struts are not rechargeable.
White smoke when cold is symptom of worn valve seals. I am assuming you also have exhaust leaks as well. Oil dripping onto the exhaust will not emit smoke unless it is covered. Check the seal around the oil cooler and wettness at the exhaust manifold.
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 11-19-2003, 02:44 PM
Let's go shooting.
Dark Skies's Avatar
Nope - buy new ones.
Not sure about the smoking - never experienced it myself.
Ulead gif animator is quite a good prog. Search around the net and you'll find a demo I'm sure. Gif movie gear is another good one. Free trial at:
http://www.gamani.com/
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Manute's Avatar
>White smoke when cold is symptom of worn valve seals. I am assuming you also have exhaust leaks as well. Oil dripping onto the exhaust will not emit smoke unless it is covered. Check the seal around the oil cooler and wettness at the exhaust manifold.>
May be,but if it is worn valve seals....why smoke is coming from the very bottom of the engine?Donīt have a n elevator,but need to see it...really intriguing me.
http://www.gamani.com/ [/B][/QUOTE] <
Thank you! Seems good,iīll try it!
85ī5 951
Old 11-19-2003, 03:39 PM
ae1969's Avatar
Send a message via ICQ to ae1969
More than likely your camshaft housing is leaking at the gasket..... The oil drips down directly on your exhaust headers......
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-19-2003, 10:45 PM
Manute's Avatar
I bet itīs this the most possible thing. So iīm thinking in two test thaat maybe clarify it...
First of all,i can put a bit of oil in an exhaust pipe, and then start the engine...when it gets warmer,smoke should be more or less at the same time and intensity than the main smoke.
And second,when smoke starts to appear,i shut down the engine...so if it is because of burning oil due to that leak,i suppose itīll keep smoking for a seconds.If it was exhaust leaks,for example,it will stop suddenly.
Do you think thatīs logical?
And...what gasket are you meaning exactly?Iīm not sure what are you meaning due to translation...what is exactly the housing?
85ī5 951
Old 11-19-2003, 11:28 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
PS hose leak. Is the tank oily?....When the hose goes it will leak on to the exhaust manifold. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-20-2003, 03:51 AM
I vote for the camtower gasket - little drips onto the manifold make for smoke - but it isn't really "White" as much as dirty dirty dirty white (aka black).
Jake
1983 Euro 944 (Mine)
2000 BMW 323i (Hers)
1997 Sentra (unclaimed!)
Old 11-20-2003, 05:34 AM
Manute's Avatar
Thanks! Need to check it later...
Smoke is darker white,may be is not dirty dirty dirty
As i said,iīll put oil in the exhaust and see if itīs the same smoke type.
85ī5 951
Old 11-20-2003, 06:30 AM
ae1969's Avatar
Manute clean the area with brake cleaner while the car is cold......
Start it up and watch for leaks.....
Old 11-20-2003, 09:40 AM
Manute's Avatar
Iīll try that Alex
I tried my test...i put a drop of oil or two with the dipstick(itīs incredible how they spread only a pair of drops),in the exhaust...at about 10-20 seconds after start the engine,became expelling the same smoke...So itīs clear itīs due to an oil leak.
It keeped smoking for about 5 minutes,the stop the engine and smoke a bit,then finished.Then restarted,but no visible smoke at all,only smell of oil.
Itīs difficult for me to check that leaks without an elevator,but iīll make a way.Thanks!
85ī5 951
Old 11-20-2003, 03:19 PM
ae1969's Avatar
Maybe you should try pouring gasoline on it and see if that makes it go away.
Old 11-20-2003, 03:21 PM
Actually, your test is useful... if it's the same smoke exactly, and you DO smell oil but don't SEE it after a the first ten minutes, I'm willing to bet its the cam tower seal. Little bits of oil could leak out and until the oil and exhaust manifold are at similar temps there will be smoke. This will get worse and worse until you fix it... which is easier on the S than the NA (maybe the only thing?) because in order to remove the cam shaft housing you must remove the cam gear - which means messing with the timing belt.
GOOD TIMES!
I hated this job more than life itself - but I made it through my learning curve just fine and it's been solid ever since.
To confirm this is a leak area, clean the side of the cam tower above the exhaust manifold (when cool), then watch as the car is idling - or have someone up the oil pressure a bit (transient revs) with you standing there watching. You should be able to locate the oil leak to the front or back of the camshaft cover gasket (usually the back - but mine was the front) after a few minutes of inspection.
No lift required.
Jake
Old 11-20-2003, 03:46 PM
ae1969's Avatar
Yup X-ray I agree with you..... slowly been guiding Manute there.
The gasket just breaks down over time but at least its cheap. Also, those bolts are at such a low torque is that they can loosen over time if not torqued properly. I have found the one closest to the cam gear is always a little loose since its normally hard to get in there with a torque wrench with the power steering reservoir in the way.
Old 11-20-2003, 04:41 PM
Manute's Avatar
Yes i think the same...The only thing is that the real smoke appears after a pair of minutes,and the test one only a seconds,because itīs closer to the cylinders.So that means the drops fall way far to the bottom till they encounter the exhaust.But i also think cam tower gasket is the most likely.
Btw,i checked it slightly (donīt had much time) and everything looked good.However,i saw a little drop can spread and smoke a lot,so maybe is a very little and slow leak.May be the best way is seeing the origin of smoke,and then follow it upwards to the leak.
Jake,not sure to understood (due to translation,of course,not my intelligence )...you mean in my car is easier to change the gasket?What do you mean with S?Mineīs a turbo...And...what the hell,i donīt know what N/A means! I never knew it! I always tried to realize myself... It means not turbo,north american,pre 85 1/2??
If I have to remove the timing gear and touch timing stuff,i better put silicone men! iīve recently done my belt,donīt wanna mess it up!
If iīm to remove nothing about timing,iīll change the gasket.
Iīll look better for the leak as you said with my father and a lamp.
Damnit,you canīt really get bored with this cars!
Next expensive or difficult repair and sure iīd try pouring gasoline Alex! A gallon and a match!
Not really,love it so much...but always with some trouble...Hey itīs like a wife!!
85ī5 951
Old 11-21-2003, 12:45 AM
OKay:
NA = normally aspirated
Unfortunately, getting to the gasket on an 86 turbo will require the cam gear removal (I'm ~80% sure of that - not having that car in front of me, can't remember 100%).
So, yeah, you'll have to mess with the belt.
Sorry.
The leak from that gasket isn't a "squirter"; it's always slow - so you're results are in line with our opinion... it's likely the camshaft cover gasket.
Jake
Old 11-21-2003, 06:25 AM
Let's go shooting.
Dark Skies's Avatar
Originally posted by FR Wilk
Exactly like a wife. It will leave you pennyless and homless sitting in a chair with a gun in you lap. Too poor to afford the bullets.
Sounds like a story behind that embittered comment.
From the long list of previous owners my car is more like the town strumpet
Old 11-21-2003, 06:48 AM
Manute's Avatar
Originally posted by 97XRAY
OKay:
Sorry.
Oh my god,not more complications...You are not sure,but if there is a chance that could be tricky,risky,and expensive,for sure itīs my case!
Btw,iīm changing my oil when i finish the can,iīll put a more dense one with a product to cover cracks,hope this helps.If not...wellcome silicone!
Yes Darky...something happens with Willy...Cīmon,here are your friends,tell to us!
Mineīs not a wife but a strumpet too,i can count at least five POīs,and i have a 10 year period i know nothing about the car....
And you?How many POīs?
Oh,one last thing...how much costs the pneumatic struts?
85ī5 951
Old 11-21-2003, 10:52 AM
I have a lot of fun reading your posts, Manute.
Keep them coming!
Jake
Old 11-21-2003, 11:28 AM
Let's go shooting.
Dark Skies's Avatar
Originally posted by Manute
[Mineīs not a wife but a strumpet too,i can count at least five POīs,and i have a 10 year period i know nothing about the car....
Oh,one last thing...how much costs the pneumatic struts? [/B]
I have eight previous owners listed.
Struts (pattern) on the front are about Ģ10
Struts (pattern) on the rear are Ģ26
Not sure what that translates to in that Toytown Euro stuff you're using over there. It's almost Christmas so a really big bag of chocolate money would probably do it.
Old 11-21-2003, 11:57 AM
