JH924S's Avatar
Send a message via AIM to JH924S
Post SHift KNOBS
I pulled off the shift knob but it looks like platic is around the metal beneath it. so do you cut it of to replace it with say a momo or aftermarket knob.
Old 08-24-2001, 02:18 PM
lordgrommit's Avatar
Post
That is the knob all you have done is to remove the leather around it. the base of the knob there is a spring clip that holds it onto the shift lever the lever is square so you cannont use an aftermarket shift lever unless you cut it off and weld in a steel rod.
Matt
Old 08-24-2001, 11:03 PM
Post
there are adapters that come w/ the after market shift knob that you can jam over the square shifter, it is a better idea to get a round metal tube and put it over the shifter then put the shift knob on that because the adapters are plasic and won't last long on the square end.
Old 08-25-2001, 01:29 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
I just made a short shifter...
Or more accurately I just cut both the shifter knob, and the lever, matched them again, and now the throw is reduced by over 30%.
Ahmet
It's all the driver...
My page [email protected]
Porsche owners Gallery.../My 944
Old 08-25-2001, 06:33 PM
