Cabin noise reduction options ...
If there were one basic characteristic I would change about my 84, it would be to make the cabin a bit less noisy.
The road slap from the tires and the exhaust noise combine to reduce the comfort level for my old and well used ears ...
With this in mind, I was wondering if anyone here as tried the quietcoat, dynamat or brown bread products?
Kind Regards,
DL
84 944 5spd
Maint. & Fixes made thanks to the help received on this board:
Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter.
Old 12-26-2003, 09:44 PM
Don 944 LA's Avatar
a little lighter on the accelerator would do the trick.
I have found that my hood pads are gone ( hence the peeling paint on the hood ) I'm sure that would cause noise. Also check the engine / firewall area. I have seen pictures that show padding where mine has since gone.
I personnaly have in the back of my mind that once I take care of the obvious things to always put some sort of padding or insulation in any area that I do work on.
I would love to put some sort of coating on the engine compartment , If I ever have to remove the engine.
Any work on the doors will find them full of padding etc...
Don
1984/85 944na
Gold exterior / Black interior
Los Angeles / San Diego
Lookin for ideas etc...
Old 12-26-2003, 09:58 PM
SoCal Driver's Avatar
A lot of wind noise is from the recessed windshield.
I've found that new tires are much quieter than worn tires.
Another thing to check are the rear bearings. When these are worn they make a constant low rumble.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-26-2003, 11:39 PM
Don 944 LA's Avatar
Is there another type ???
maybe some cowl relief ports ??
just me thinkinking aloud
1984/85 944na
Old 12-27-2003, 01:06 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I am planning to brown-bread the entire interior of my car.
Mmm, that's a lot of sandwiches!
HA! I beat all of you to that!
Anyhoo, I am building a competetion system in my 944, so I am doing it out of necessity, however, I as well find that the road noise is a little much some times. I just removed a large box from my hatch area, and now I can hear my exhaust, jeez, I think it's time for a new muffler.
Anyhoo, I was thinking, if you dynamat/fatmat/brown-bread the interior, you will have to pull the seats, all the carpet, door panels and perhaps even the roof down. It is a lot of work, only do it if you are dedicated to eliminating the noise.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-27-2003, 02:23 AM
Let's go shooting.
Dark Skies's Avatar
I've found some judiciously placed sticky backed foam in the sunroof (where the deflector makes contact when the hatch is in place) and tangs cuts down a fair bit of rattling in that area.
Thicker under carpeting works well too - I get it from a regular household carpet outlet.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 12-27-2003, 05:44 AM
The post 85.1 cars have thicker padding under the carpets. Especially in the back carpet area.
They also have a flush mounted windshield. You can buy the three pieces that spaces the windshield the next time yours needs replaced and make your early 944 like the later 944's. Think you also have to buy two of the thicker support blocks that are at the bottom of the windshield or get them from a wrecker. The wiper arms may be different or the pivots may be a bit longer. I'll have to check the unit I have.
A note on the sunroof; you can take the liner off and put some sound deadening between it and the outer shell.
There is room in the doors for some sound deadening. I would glue it to the inside of the outer door panel. Same with the rear quarter panels.
Old 12-27-2003, 05:59 AM
Zero10's Avatar
I have a stupid question about noise. I have noticed a lot of the road noise on my cars sounds like it's either coming underneath the door, or through that panel right at the bottom of the door.
Is this a bad door seal, or is this a problem in the design?
Buy my parts!
Old 12-27-2003, 10:35 AM
Door noise
Yep, seems like I'm hearing the road noise through my door panels as well.
I've made a material selection (QuietCoat) and I'll post here to let everyone know how it worked out. I've purchased 3 gallons of the stuff and plan to do the door panels and the 'under the carpet' parts - including the rear wheel wells.
SoCal's comment on older tires being louder than new ones rings true to me as my tires now (they are getting on in life) certainly seem louder than last year.
84 944 5spd
Old 12-27-2003, 04:56 PM
Now when I drive I keep hearing more noise! Drat!
Old 12-27-2003, 05:13 PM
vott does ziss do?
ronin's Avatar
ahh, the power of suggestion!
Old 12-27-2003, 05:29 PM
J1NX3D's Avatar
and tyre choice/ brand make a difference too
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 12-27-2003, 05:46 PM
Burn the fire.
Brando's Avatar
I found that turning up the volue on the stereo takes most, if not all, of the road noise away
Please, do post where you got your sound-solution at. I'm looking for a way to deaden the sound of the engine in my car. Preferably since there's only about ¼ of an inch of fiber-board insulation.
I've considered rhino liner, but that stuff aint easy to come by. and dynamat can get quite heavy in needed quantities.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-28-2003, 01:45 PM
Blackfoot's Avatar
http://www.b-quiet.com/hliner.html
___________
cars a plenty
Old 12-28-2003, 03:50 PM
meister member
speedracing944's Avatar
How much weight does all of this add?
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-28-2003, 04:18 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Turn up your stereo, or should I say Competition system.....
My car is naughty
Old 12-28-2003, 06:32 PM
vott does ziss do?
ronin's Avatar
hehe, turning up my "competition system" would mean stepping on the gas!!
Old 12-28-2003, 08:11 PM
suck my tail pipe
Frank B's Avatar
Oh, o.k. The term "system" is usually linked to a soiund system where I come from. I can't listen to the radio or stereo in my 944, the car has so much bass, that it kills all of the mids and lows, so I just listen to music at redlights and drivethroughs.
I'd suspect that the huge low end note generated by the exhaust is musical to some people me included, I like the cars sounds, the trans, engine whine, exhaust, it's all pretty cool.
My car is naughty
Old 12-28-2003, 09:33 PM
Zero10's Avatar
Lol turn it up, well, that still doesn't help on the judging when everything on my car rattles, they frown on that.
Anyhoo, I am curious about just how much dynamat/brown bread weighs, I do not wish to slow my car down any further.
Buy my parts!
pearldrum's Avatar
Send a message via AIM to pearldrum
I didn't think about that. I scraped mine off because it was crumbling, I guess I should buy some new stuff...
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 12-28-2003, 11:08 PM
