Angry Arrgh Out Of Ideas
IM OUT OF IDEAS GUYS! I went up there and checked everything and the car still wont start. My stepdad said the people at his work can look at it and run a diagnosis of whats wrong? Is this true? Could they find the problem cuz ARGH IM MAD AND SAD AND I MISS PORSCHEY.
86' Porsche 944 N/a
Old 03-20-2004, 09:19 AM
meister member
speedracing944's Avatar
how did your "spark" test go?
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-20-2004, 09:56 AM
i didnt get to see, i was the one cranking the car. He said he couldnt see any spark, but he heard a spark sound a few times.
86' Porsche 944 N/a
Old 03-20-2004, 10:47 AM
i dont think there was spark
86' Porsche 944 N/a
Old 03-20-2004, 10:53 AM
pearldrum's Avatar
Send a message via AIM to pearldrum
Do you have a voltmeter? You could check at the coil.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 03-20-2004, 11:27 AM
MrPants's Avatar
did you try spraying starter fluid into the throttle while cranking? if it starts and then dies you have at least some spark.
84 944 Non Alcoholic
Old 03-20-2004, 01:25 PM
no i didnt try that yet, im just gonna let the guys see if they can figure it out
86' Porsche 944 N/a
Old 03-20-2004, 07:40 PM
Chris_924s's Avatar
coil.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 03-25-2004, 06:07 AM
Friend of Warren
Come on Rock, keep with the basics. If you or whomever was looking, didn't see a spark, you need to correct that problem before you go any further.
Kurt V
Old 03-25-2004, 06:22 AM
TCMdocs944's Avatar
Rock,
Do you have the haynes manual yet?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 03-25-2004, 06:19 PM
Wolf1's Avatar
Somebody needs to go help this guy................before he burns it.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 03-25-2004, 06:49 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
hehe, seems like he has quite a few problems with his car sometimes, i remember when he got here ad asked how to put a turbo on it hehe
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 03-25-2004, 08:23 PM
Official Sponsor
vital-transform's Avatar
check the + and - wires going to the coil!
1988 - 924S Guards red, auto trans
Old 03-25-2004, 10:24 PM
ae1969's Avatar
Send a message via ICQ to ae1969
SO.... refresh us.
How did the car end up at this point ? Symptoms etc.
Kurt V spelled it out....keep it simple.
......Uhmmm I wouldnt let the the wizards that are going to plug it in and run a diagnostic on it?? Come within a rocks toss of this car...... I dont think they are going to get any error codes on this puppy... hehehe
Troubleshooting no spark is pretty straight forward on these cars..... and thankfully enough the manuals spell it out quite nicely..... but lets start from the beginning.....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-25-2004, 10:54 PM
There's a DME test manual that's pretty handy. It goes in order of the most likely culprits so that you don't waste time doing symptom-fixing instead of finding the real problem. Roughly in this order:
1. power to the DME from the DME-relay
2. correct waveforms coming from the reference-sensor
3. correct waveforms coming from the speed-sensor
4. +12v on both sides of the coil (use a bare bolt somewhere for ground-reference)
5. +12v on the rearward pin on each injector connector
6. 0v on the forward pin of each injector connector
With these simple tests, you'll most likely find the trouble spot.
Old 03-26-2004, 04:24 AM
SoCal Driver's Avatar
Why do I keep replaying Cheech and Chongs "It's the battery" skit?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-26-2004, 07:49 AM
Send a message via AIM to Trevor
He said he was slamming it into fourth and didn't get it into gear and bounced off of the rev limiter, a few miles down the road it stalled, he got it restarted and it stalled about five minutes later. Maybe he messed up the dme when he hit the limiter, could it be as simple as a new relay?
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 03-26-2004, 08:26 AM
Friend of Warren
Ahh some additional info. Did he check to see if he bent a couple of valves?
Kurt V
Old 03-26-2004, 09:02 AM
ae1969's Avatar
Was a compression check ever done ?
Old 03-26-2004, 09:26 AM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
comon' Rock.. We are all dying out here with curiosity.. What happened?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 03-26-2004, 11:21 AM
