IM OUT OF IDEAS GUYS! I went up there and checked everything and the car still wont start. My stepdad said the people at his work can look at it and run a diagnosis of whats wrong? Is this true? Could they find the problem cuz ARGH IM MAD AND SAD AND I MISS PORSCHEY.
86' Porsche 944 N/a |
meister member
how did your "spark" test go?
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
i didnt get to see, i was the one cranking the car. He said he couldnt see any spark, but he heard a spark sound a few times.
i dont think there was spark
Do you have a voltmeter? You could check at the coil.
'83 arctic silver 944 n/a Power steering? who needs it! |
did you try spraying starter fluid into the throttle while cranking? if it starts and then dies you have at least some spark.
84 944 Non Alcoholic |
no i didnt try that yet, im just gonna let the guys see if they can figure it out
coil.
TENSION YOUR SOCKS! 88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING! 87 NA Diamond Blue Metallic ~ Gone |
Friend of Warren
Come on Rock, keep with the basics. If you or whomever was looking, didn't see a spark, you need to correct that problem before you go any further.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Rock,
Do you have the haynes manual yet?
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Somebody needs to go help this guy................before he burns it.
75 914 - Undecided. 80 931 - Gone, but not forgotten. 72 914 - old toy- sold. And a whole bunch of German scrap metal shaped like 924's. Old enough to know better, and stupid enough to do it anyway! |
hehe, seems like he has quite a few problems with his car sometimes, i remember when he got here ad asked how to put a turbo on it hehe
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
Official Sponsor
check the + and - wires going to the coil!
1988 - 924S Guards red, auto trans |
SO.... refresh us.
How did the car end up at this point ? Symptoms etc. Kurt V spelled it out....keep it simple. ......Uhmmm I wouldnt let the the wizards that are going to plug it in and run a diagnostic on it?? Come within a rocks toss of this car...... I dont think they are going to get any error codes on this puppy... hehehe Troubleshooting no spark is pretty straight forward on these cars..... and thankfully enough the manuals spell it out quite nicely..... but lets start from the beginning.....
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
There's a DME test manual that's pretty handy. It goes in order of the most likely culprits so that you don't waste time doing symptom-fixing instead of finding the real problem. Roughly in this order:
1. power to the DME from the DME-relay 2. correct waveforms coming from the reference-sensor 3. correct waveforms coming from the speed-sensor 4. +12v on both sides of the coil (use a bare bolt somewhere for ground-reference) 5. +12v on the rearward pin on each injector connector 6. 0v on the forward pin of each injector connector With these simple tests, you'll most likely find the trouble spot. |
Why do I keep replaying Cheech and Chongs "It's the battery" skit?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
He said he was slamming it into fourth and didn't get it into gear and bounced off of the rev limiter, a few miles down the road it stalled, he got it restarted and it stalled about five minutes later. Maybe he messed up the dme when he hit the limiter, could it be as simple as a new relay?
1987 Black/Black (sold) 96' Jetta (RIP) 1986 N/A (Sold) 2001 Taurus noooooooooooooo! ![]() 1993 325is |
Friend of Warren
Was a compression check ever done ?
What would Darth Vader do
comon' Rock.. We are all dying out here with curiosity.. What happened?
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
