adida(r 944)'s Avatar
Question compresion tested... what do you think
i just did a compresion test on my engine and here is what i come up with. tell me if good, bad, or normal, cuase i have no clue.
this is also my first time i did a compresion test so i may have done it wrong...
this is how i did it, after changing oil and oil filter (helped cure some of my ticking, but now i think i got exhaust gaskets leaking, exhaust nuts not tightend all the way whoops, anyway back to compresion testing)...
i did each cylinder individualy i also did these test after i let the car warm up and pulling plugs. and did them several times.
with a push button i hand crafted that attached to the starter with aligator clips so i didnt have to use gogo gadget arms to turn it over and watch the compresion tester gauge.
turning over once: 120 psi on cylinders #1 #2 #3 and #4
turning over twice: 140 psi on cylinders #1 #2 #3 and #4
turning over 3 times: 155 psi on cylinders #1 #2 #3 and 160 psi on #4
turning over 4 times: 170 psi on #1 and #3 175psi on #2 and #4
any other turn overs result as same as turning over 4 times +/- 5 psi.
also waited after presured up to see if the psi went down on there own without hitting the release button and nope didnt... so umm whatcha think?
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 05-09-2004, 11:09 PM
a.n.other's Avatar
That seems very close to what i got in my '84 when i did it a few months ago (mine might have been 180psi but not much more) - and i was very pleased with it, but can't offer any more 'technical' info than that!
Is your car running well? If so, i'd be happy with 170's all round. I think the Haynes manual says something about 150psi being fine. Do a search on compression and psi and see what other people got.
Andy
Lowered '84 944 no longer smokin!
Lowered, adjustable KONI shocks, APE chip, K&N panel filter, Strut tower brace, Blue Fuchs (+ anything else i've not discovered yet!)
http://photos.yahoo.com/shineyblue944
Old 05-10-2004, 12:11 AM
AFJuvat's Avatar
Looks like a good motor to me
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-10-2004, 08:06 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Don't listen to AFJuvat.....
That motor is crap...........
I will take it off your hands if you pay shipping...
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-10-2004, 09:47 PM
03 Eclipse GS
Old 05-10-2004, 10:04 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Just curious, but did you pull all the spark plugs when you did the compression test?
Be happy with those numbers, mine are all about 50-70psi lower.
200ish is wonderful, 170 is perfectly good, 150 is getting troublesome, 130 it's rebuild time, 100, well, then you're me =)
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 05-14-2004, 12:03 AM
KLR KLR is offline
KLR's Avatar
These gauges are not always accurate. 170+ is perfectly good, you really just want to be sure that it's pretty even across all four. If it ain't, then you've got problems to fix.
1987 951 - Stone Gray / Burgundy
15psi Guru Chips, Reliaboost, 3-bar FPR, KW Variant 3 Suspension, OE Euro Driving Lights, Iceshark Wiring Kit
Old 05-14-2004, 10:52 AM
