Driver
With the engine pulled...
OK,
Car will be back from the auto body shop next week. Engine with be pulled soon after, & sent to Broadfoot. What should I absolutely not forget to do once I have the engine out? HERE IS A RUST SHOT TO MAKE ALL OF YOU FEEL BETTER ABOUT YOUR CARS. Thanks, GHEN
'87 944 |
Head gasket, rear main seal, front seal, any other misc. seals and gaskets
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
THAT was never fixed right from before.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
i would say look at front/rear main seals, timing belts/seals, water pump, and motor mounts. maybe check compression while youre at it
84 944 Non Alcoholic |
Driver
Well the engine is getting EVERYTHING done, I mean while I have the engine out, what else should I look at?
GHEN
'87 944 |
entertaining the idea
You could thoroughly clean the engine bay
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
That was some crappy body work they did .........
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Burn the fire.
Clean the engine compartment real well. Replace suspension bushings with urethane, replace your ball joints, new torsion bars, upgrade to Aluminum torque tube, lightened flywheel? Spring-center clutch...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
