turn signals
I swapped steering wheels (from my 924s parts car to my '86 944) and now my turn signals don't shut off after a turn. It makes the clicks like it should, but it doesn't turn off. Is there something I can adjust, or are the wheels incompatible (they look identical)?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
Burn the fire.
You're missing the return piece on the bottom of the wheel. You'll see it as part of a cylindricalpiece on the bottom that sticks out... that's the reset thingie.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Could also be the wrong canceller/finger thingy. Think there is a difference between the old 944 and the new. You should be able to swap them.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Gentlemen, thanks for your responses. It was indeed the protrusion. SoCal, you are correct, the protrusion is 180 degrees off between the '87 and '86. I swapped mine from wheel to wheel, but suspect that they could just be turned 180 degrees and the wheels would switch from new to old style (there is even another hole for the horn lead to fit through).
