Throttle Response Cam
I wanted to put on a Weltmeister throttle response cam but it says only for manual cars is there a difference that I cant install it?
Old 06-25-2004, 05:54 AM
I don't know why they would specify for manual transmission only...unless there is additional cable attached to the current trottle cam for cruise control.
Examine your current throttle cam assembly...
Manual transmission cars have a single braided cable coming from the firewall (gas pedal) to the lever arm of the throttle cam. There is a return spring on the cam, and another return spring on the shaft. A single nut retain the whole assembly.
If yours is like this...go ahead and replace the cam.
The new throttle cam eliminates the lever arm, which gives the gas pedal a 1:1 ratio. i.e. you don't depress the gas pedal as far to rev the engine.
JM
Old 06-25-2004, 06:43 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
They're a waste of money.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 06-25-2004, 10:14 AM
There are two cables coming out of it.
Old 06-25-2004, 10:21 AM
Burn the fire.
Brando's Avatar
Want more throttle? Remove the plastic bolt that sticks out of the stop for the accelerator pedal. Then continue to floor it.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-25-2004, 10:38 AM
I'm off the hook.....
It's eye candy for your foot.
Gawd, I wish I had invented it. I'd be rich and fat!
No, I don't sing. Based there for too long.
Old 06-25-2004, 12:17 PM
Burn the fire.
Brando's Avatar
Need throttle response?
Stomp on the pedal quicker.
Old 06-25-2004, 01:41 PM
adida(r 944)'s Avatar
i got one of those installed and noticed no more throttle response than the stock setup. just looks pretty when you open the hood to find a different color other than aluminum and flat black
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 06-25-2004, 09:21 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
yeah, auto tranny has a kickdown cable. and the mount is incompatable. totally different critter.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 06-27-2004, 01:27 AM
